2017 Mazda Premacy Review
The Mazda Premacy is a seven-seater minivan that made its debut in 1999 and has evolved to meet the changing preferences of clients over the years until its discontinuation in 2018. As much as it has been in the shadows of the Toyota Wish, it boasts a spacious cabin that is very versatile and can be easily configured to carry people or haul cargo. Compared to its rivals, the Premacy gives good value for money. It competes with the Toyota Wish, Subaru Exiga, Nissan Lafesta, and Honda Freed.
2017 Mazda Premacy front view
The first generation of the Mazda Premacy codenamed CP launched its production in 1999 and continued up to 2005. The second generation designated as CR was manufactured from 2005 to 2010. The third generation of the Mazda Premacy was designated as CW and it was in production until its discontinuation in 2018.
The 2017 Mazda Premacy comes with two engine options, a 2.0 L (Petrol), and a 2.2 L (Petrol) linked to either a manual or automatic transmission.
2017 Mazda Premacy Grades
- Mazda Premacy 20C- This grade comes with a power-assisted steering wheel, Bluetooth connectivity, power mirrors, air conditioner, and an anti-lock braking system.
- Mazda Premacy 20S- This grade has a CD player, power windows, a centralized door lock, keyless entry, a digital meter, power slide doors, AM/FM Radio, a rear window defroster, and power door locks.
- Mazda Premacy 20 C SKYACTIV- This grade boasts a navigation system, multiple airbags, fog lights, side skirts, a reverse camera, Bluetooth connectivity, and climate control
- Mazda Premacy 20S SKYACTIV- This grade is fitted with an AM/FM Radio, a navigation system, a centralized door lock, an anti-lock braking system, power slide doors, and a CD player.
The 2017 Mazda Premacy has a spacious cabin that accommodates seven passengers. The first row has plenty of legroom and headroom and the comfy seats can be reclined to match a desired preference. The second row boasts sufficient knee room and legroom. Due to limited space, the third-row seat is only ideal for kids.
2017 Mazda Premacy first row
2017 Mazda Premacy second row
2017 Mazda Premacy third row
The 2017 Mazda Premacy boasts multiple storage compartments that are designed to improve the comfort of the passengers. A glove box, door panel storage, and two cupholders are included in the first row. The second row has door pockets, jacket pockets, and storage beneath the seats which can be useful in keeping valuable items like a laptop and other accessories. Third-row seat occupants have access to cupholders.
The 2017 Mazda Premacy has a sizeable cargo area that can accommodate small and medium-sized luggage. The second and third-row seats can be folded to create more room for more cargo.
2017 Mazda Premacy boot space
The 2017 Mazda Premacy has a dynamic and athletic look. The front end incorporates the Mazda’s distinctive grille flanked by angular headlights that lend it a modern look. The Mazda’s prominent emblem is adorned on the slanting bonnet and is used to stamp its presence wherever it traverses. Sculpted lines on the hood which are also present in the side profile improve the aerodynamics of the vehicle.
The wheelbase of the Premacy is slightly longer hence resulting in a spacious interior. Owing to the streamlined roof line and slanting bonnet, occupants have a commanding view of the oncoming traffic. The electronically powered sliding doors allow passengers to effortlessly embark or disembark from this minivan. The side skirts as well as the wheel arches that are well defined improve the overall aesthetics of the Premacy.
The rear features tail lights and turn signals. The roof spoiler compliments very well the slightly sloping roofline. A reverse camera is also present to aid the driver especially when navigating in confined spaces.
2017 Mazda Premacy Front and Side View
2017 Mazda Premacy rear and side view
2017 Mazda Premacy rear view
2017 Mazda Premacy Safety Features
The 2017 Mazda Premacy features multiple airbags, stability control, and an anti-lock braking system.
2017 Mazda Premacy Fuel Consumption
2017 Mazda Premacy 2.0 L petrol engine consumption- 14.8 km/l on average
2017 Mazda Premacy 2.2 L petrol engine consumption- 14.3 km/l on average
2017 Mazda Premacy Acceleration
2017 Mazda Premacy 2.0 L petrol engine accelerates from 0-100km/h in 11.3 secs
2017 Mazda Premacy 2.2 L petrol engine accelerates from 0-100km/h in 10.8 secs
The 2017 Mazda Premacy Fuel Tank Capacity: 58 liters
Ground Clearance: The 2017 Mazda Premacy has a ground clearance of 6.1 inches which is below the required standard of 6.5 inches on Kenyan roads.
Mazda Premacy spare parts are easily available in major towns. However, its body components are more expensive compared to other vehicles in the same category.
The 2017 Mazda Premacy delivers a smooth and comfortable ride. Given that the steering wheel is power-assisted, it gives responsive feedback to the driver hence making the ride enjoyable and effortless. The cabin is well-insulated to prevent outside noise from bothering the passengers. The engine works in tandem with the transmission system to deliver a smooth start and decent acceleration.
The braking system is sharp and robust hence it can stop this car in a matter of seconds to avoid any kind of mishap. The Premacy can carry up to seven people and all of them will have a pleasant ride thanks to its rigid suspension system that delivers its function perfectly. Owing to its approach and departure angles as well as its low ground clearance, it is not recommended to traverse off-road terrains as you could damage its body components which are expensive to repair, or even replace. Stability control and anti-lock braking system play a big role in enhancing the Premacy’s stability.
2017 Mazda Premacy steering wheel & gear shift
2017 Mazda Premacy cluster meter
2017 Mazda Premacy engine
2017 Mazda Premacy wheel
2017 Mazda Premacy suspension system
The 2017 Mazda Premacy is considered a reliable car. However, its low ground clearance hinders it from being driven off-road. Just like any other vehicle, the Premacy also experiences mechanical troubles. Oil leaks, engine misfiring, and erratic braking are the most commonly reported issues by Premacy owners. Regular service and maintenance are required to avoid experiencing such troubles.
Refer to the Mazda Premacy buyer guide for a thorough reliability report. We also urge that you always follow the instructions in the owner’s manual.
Mazda Premacy Competitors: Toyota Wish, Subaru Exiga, Nissan Lafesta, and Honda Freed.
What we like about the 2017 Mazda Premacy
Stellar fuel economy
Advanced safety features
Electronic-powered sliding doors
Spacious cabin
The 2017 Mazda Premacy makes an excellent family car owing to its three-row seating configuration which can be easily configured to transport goods by folding the second and third-row seats. Its stellar fuel economy has made it to be embraced in the transport industry as one is guaranteed to maximize investment returns. Urban inhabitants can use this car as a daily driver as it does not compromise on its exterior styling. The only place that the Premacy loses is in its inability to traverse off-road terrains owing to its low ground clearance. Individuals on a tight budget may not be in a position to own this car as its purchase price is slightly higher.
We have developed a network of trusted dealers in Japan, South Africa, the UK, and Dubai who supply us with exceptionally high-quality vehicles. Eliminate middlemen and showroom costs by importing the car with us and saving up to KES 500,000. The import process takes 45-60 days from Japan & one week from South Africa and the car is delivered to your doorstep. Click here to choose the best varieties of Mazda Premacy.
2017 Mazda Premacy side view
