2017 Mitsubishi L200 Review
The Mitsubishi L200 is a midsize pickup truck that is also marketed as the Mitsubishi Triton. Its presence in the Kenyan market has not been largely felt owing to the fact it is up against formidable competition from the likes of the Toyota Hilux, Ford Ranger, Volkswagen Amarok, Nissan Navara, Isuzu D-MAX, and Nissan Hardbody. However, as much as it does not have a higher rating than its rivals, it has excellent off-road capabilities, High towing capacity, and can make a good commuter vehicle for urban dwellers courtesy of its distinct exterior styling.
2017 Mitsubishi L200 front and side view
The first generation of the Mitsubishi L200 started its production back in 1978 and continued up to 1986. The second version of the L200 was manufactured from 1986 to 1996. From 1996 to 2005, the L200’s third generation was in production. The fourth iteration of the L200 commenced its production in 2005 and continued up to 2015. The fifth generation was in production from 2015 to 2023. In this period, the L200 underwent major facelifts that saw it have a new, sleek, and modern exterior styling. The Mitsubishi L200 is currently in its sixth iteration.
The 2017 Mitsubishi L200 comes with two engine options, a 2.4 L (Diesel), and 2.5 L (Diesel) linked to either a 5/6-speed manual transmission or a 5/6-speed automatic transmission. Click here to purchase the 2017 Mitsubishi L200 Buyer’s Guide.
Mitsubishi L200 Body Configurations
A. Single Cabin
B. Extended Cabin
C. Double Cabin
2017 Mitsubishi L200 grades
1. Mitsubishi L200 GL- This grade comes with Bluetooth connectivity, a centralized door lock, a 12-volt power outlet, chrome door handles, and power mirrors.
2. Mitsubishi L200 GLX- This grade features multiple airbags, blind spot monitoring, traction control, an anti-lock braking system, a hill start assist, power windows, and an AM/FM Radio.
3. Mitsubishi L200 GLS- This grade has parking sensors, chrome door handles, chrome-accented mirror caps, climate control, stability control, a lane departure warning, and a rearview camera.
4. Mitsubishi L200 Exceed- This grade is fitted with blind spot monitoring, Bluetooth connectivity, smartphone integration, privacy glass, LED daytime running lights, and a power-assisted steering wheel.
The 2017 Mitsubishi L200 has a more practical cabin with plastic touches covering the majority of the dashboard. The first row has sufficient legroom and headroom and its seats can recline to accommodate a desired preference. The second row of the double cabin features ample knee room and headroom. Taller individuals might find the second row uncomfortable. The second row of the extended cab is only ideal for kids for it has a limited knee room.
2017 Mitsubishi L200 first row
2017 Mitsubishi L200 second row
The 2017 Mitsubishi L200 encompasses several storage compartments used to improve the comfort of occupants. The single cab features door panel storage a small center console, two cupholders, and a glove box.
The Extended cab has two cupholders, a center console, door pockets, and a glove box in the first row. The second row includes door panel storage only.
The double cabin’s first row has two cupholders, a glove box compartment, door panel storage, and a center console. Its second row is fitted with jacket pockets, door pockets, and two cupholders mounted on the armrest.
The 2017 Mitsubishi L200 comes with three body configurations that result in varying cargo space. The single cab has the biggest load area followed by the extended cab and finally the double cabin. This pickup can haul tons of cargo over a long distance.
The 2017 Mitsubishi L200 has a well-blended exterior styling that depicts aggressiveness, muscular, and modern feel. The L200 is identifiable through its chrome-accented grille with the Mitsubishi logo adorned on it and mostly used to stamp its authority wherever it traverses. The hood has well sculpted lines and a hood scoop depending on the owner’s taste of styling can be added to boost its aggressiveness. LED daytime running lights and the swept-back headlights lend the L200 an upscale look. The lower bumper is fitted with air vents and fog lights.
The side profile features chrome door handles. The mirror caps also boast some chrome embellishments. Running boards are well positioned on this pickup to aid passengers to effortlessly board or alight the vehicle. Some trim levels come with roof rails as standard while others do not. The fenders that house the wheels of the L200 make the vehicle look more muscular.
The rear-end features tail lights and turn signals. Its large tailgate is manually operated. The lower bumper has a tow hitch that can be used to pull a trailer and this might be ideal for adventurous individuals. The bed area depending on the cab configuration is designed to accommodate various tons of freight.
2017 Mitsubishi L200 front view
2017 Mitsubishi L200 rear and side view
2017 Mitsubishi L200 rear view
2017 Mitsubishi L200 Safety Features
The 2017 Mitsubishi L200 features multiple airbags, traction control, lane keep assist, traction control, cruise control, anti-lock braking system, electronic brake force distribution, brake assist, and blind spot monitoring.
2017 Mitsubishi L200 Fuel Consumption
2017 Mitsubishi L200 2.4 L diesel engine consumption- 13.3 km/l on average
2017 Mitsubishi L200 2.5 L diesel engine consumption- 12.8 km/l on average
2017 Mitsubishi L200 Acceleration
2017 Mitsubishi L200 2.4 L diesel engine accelerates from 0-100km/h in 12.2 secs
2017 Mitsubishi L200 2.5 L diesel engine accelerates from 0-100km/h in 11.5 secs
The 2017 Mitsubishi L200 Fuel Tank Capacity: 75 liters
Ground Clearance: The 2017 Mitsubishi L200 has a ground clearance of 7.8 inches.
Mitsubishi L200 spares, especially body parts are not as easily available in Kenya and they are sometimes expensive. Service parts are fairly affordable and easy to find within Nairobi and other major towns.
The 2017 Mitsubishi L200 offers a sturdy and comfortable ride. Its steering wheels adapt to road bends making it effortless to drive. The front wheels have an independent double wishbone suspension system as the rear is fitted with leaf springs which is very convenient especially when it comes to hauling tons of cargo, and furthermore, it offers a good balance when it comes to comfort and practicality.
The L200 comes standard with the selectable 4WD system that enables it to cruise any kind of terrain whether on mud, gravel, or sand without getting stuck. Its approach and departure angles not forgetting its high ground clearance allows it to exploit any kind of terrain without the fear of damaging its body components.
The brakes are very robust and come in handy when trying to avoid any kind of collision as it can bring this pickup to a complete halt in a matter of seconds. The cabin is well insulated to prevent outside noise likely from the engine or noises picked from rough road surfaces from making the occupants feel uncomfortable.
Other technologies incorporated in the Mitsubishi L200 to enhance its performance and stability include traction control, an Anti-lock braking system, and blind spot monitoring.
2017 Mitsubishi L200 steering wheel
2017 Mitsubishi L200 manual gear shift
2017 Mitsubishi L200 engine
The 2017 Mitsubishi L200 is regarded as a reliable vehicle. It has a high ground clearance that enables it to cruise on any kind of terrain. However, just like any other pickup, the L200 is not immune to problems. Fuel filter fault, head gasket fault, and leaf springs crack are the most commonly reported troubles in this vehicle. Regular service and maintenance are required to avoid experiencing such kind of issues.
Mitsubishi L200 Competitors: Toyota Hilux, Ford Ranger, Volkswagen Amarok, Nissan Navara, Isuzu D-MAX, and Nissan Hardbody.
What we like about the 2017 Mitsubishi L200
Off-road capability
Excellent towing capacity
Fuel efficiency
Limited tech features
Some variants are very expensive
The 2017 Mitsubishi L200 is a pickup truck that blends very well both in the metropolis owing to its attractive exterior styling or rural areas simply because of its bed load that can be used to haul freight from the farm to the market. It has outstanding off-road capabilities as well as good towing capacity. Despite facing serious competition from its rivals who have dominated the Kenyan market for quite some time, its performance in terms of comfort and practicality cannot be written off. Because of its high acquisition price, individuals on a tight budget may not be able to own it. Click here to download the 2017 Mitsubishi L200 Owner’s Manual.
We have developed a network of trusted dealers in Japan, South Africa, the UK, and Dubai who supply us with exceptionally high-quality vehicles. Eliminate middlemen and showroom costs by importing the car with us and saving up to KES 500,000. The import process takes 45-60 days from Japan & one week from South Africa and the car is delivered to your doorstep. Click here to choose the best varieties of Mitsubishi L200.
