2018 Honda Fit Review
The Honda Fit has built a formidable brand for itself as it is among the most sought-after cars in Kenya. In other regions, it is known as the Honda Jazz. Even though its engine capacity is not as powerful as its competitors, it wins a lot when it comes to fuel economy, a factor that will appeal to a number of commuters residing in urban areas, and cabin room which is very spacious for its class. It faces stiff competition from the likes of the Toyota Vitz, Suzuki Swift, Mazda Demio, and Nissan Note.
2018 Honda Fit front and side view
The first generation of the Honda Fit designated GD launched its production in 2001 and continued up to 2007. The second generation of the Fit which was known as GE was in production from 2007 to 2013. From 2013 to 2020, the fourth generation of the Fit codenamed GK was manufactured. The GR marks the fourth iteration of the Honda Fit whose production is currently ongoing.
The 2018 Honda Fit comes with two engine options, a 1.3 L (Petrol), and a 1.5 L (Hybrid) connected to a Continiously Variable Transmission (CVT). Click here to purchase the 2018 Honda Fit Buyer’s Guide.
2018 Honda Fit Grades
  1. Honda Fit 13G F Comfort- This grade comes with an air conditioner, a navigation system, Bluetooth connectivity, a USB port, and power windows.
  2. Honda Fit 13G L Honda Sensing- This grade has an anti-lock braking system, power mirrors, halogen headlights, and a CD player.
  3. Honda Fit 13G RS- This grade is fitted with an AM/FM Radio, power windows, privacy glass, cruise control, and a USB port.
  4. Honda Fit 13G F Package- This grade boasts power mirrors, Bluetooth connectivity, a centralized door lock system, and multiple airbags.
The 2018 Honda Fit has a roomy cabin that is plain and basic. The first row has very comfortable and supportive seats with ample legroom and headroom. These seats can be reclined to accommodate a desired posture. The second row is quite impressive as its occupants enjoy sufficient knee room and headroom.
2018 Honda Fit first row
2018 Honda Fit second row
The 2018 Honda Fit has numerous storage compartments that are used to store or hold items like paperwork, beverages, key fobs, soft drinks, and other staff. A glove box compartment, a small center console, door panel storage, and two cupholders are included in the first row. The second row has jacket pockets, and door pockets only.
The 2018 Honda Fit has a spacious load area that can hold small and medium-sized luggage. It is one of the biggest boot spaces in the hatchback category. To create more room for more cargo, the rear seats can be retracted.
2018 Honda Fit boot space
The 2018 Honda Fit has a modern and more functional exterior styling. The front end features a small grille adorned with the prominent Honda emblem that is used to stamp its presence. The angular headlights as well as the fog lights incorporated in the lower fascia lend it an upscale look. The hood has nicely sculpted lines and it is somewhat slanting hence giving the occupants an excellent view and command of the oncoming traffic. Air vents are neatly placed on the lower fascia and it aids in cooling the engine. To enhance the sportiness of the Fit, a lip spoiler with some carbon fiber embellishments can be installed on the lower bumper.
Conservativeness dominates the side profile as the mirror caps as well as the door handles are body-colored. Higher trim levels feature a sunroof which creates ambient lighting in the cabin. Contours running from the front wheel to the rear wheel are very noticeable and help in improving aerodynamics. The rear encompasses a roof spoiler which enhances the overall appearance of the Fit and tail lights.
2018 Honda Fit front view
2018 Honda Fit rear and side view
2018 Honda Fit rear view
2018 Honda Fit Safety Features
The 2018 Honda Fit features multiple airbags, stability control, brake assist, and an anti-lock braking system.
2018 Honda Fit Fuel Consumption
2018 Honda Fit 1.3 L petrol engine consumption- 16.1 km/l on average
2018 Honda Fit 1.5 L hybrid engine consumption- 27.0  km/l on average
2018 Honda Fit Acceleration
2018 Honda Fit 1.3 L petrol engine accelerates from 0-100km/h in 12.1 secs
2018 Honda Fit 1.5 L hybrid engine accelerates from 0-100km/h in 9.7 secs
The 2018 Honda Fit Fuel Tank Capacity: 40 liters
Ground Clearance: The 2018 Honda Fit has a ground clearance of 5.3 inches which is below the required standard of 6.5 inches on Kenyan roads.
Service parts such as plugs, filters, brake pads, and shocks are widely available in Kenya. Body parts are available in major towns. Its spare parts are fairly priced and are comparable in price to Toyota Vitz.
The 2018 Honda Fit has a smooth and comfortable ride. Its compactness allows it to easily maneuver in confined spaces. The driver has full control of the car as it is effortless to steer it for it adapts very well to road bends. Compared to its competitors, the cabin is not well-insulated to prevent outside noise from causing discomfort to the passengers. The suspension system is rigid and provides a firm ride on highways and also cushions the occupants from unstable motions when traversing on rough surfaces.
The braking system is very robust and up to the task as it can bring this car to a complete stop in a matter of seconds which helps in avoiding possible collisions. Owing to its low ground clearance, you risk damaging its body components when you attempt to drive in off-road terrains. Other technologies incorporated in the 2018 Honda Fit to improve its stability include an Anti-lock braking system and electronic stability control.
2018 Honda Fit steering wheel & gear shift
2018 Honda Fit wheel
2018 Honda Fit suspension
The 2018 Honda Fit is a reliable car. Because of its low ground clearance, it is advisable not to drive it in off-road terrains as its body components can be damaged. Transmission issues are the most commonly reported problem in this car. Regular service and maintenance are required to avoid experiencing such problems.
Honda Fit Competitors: Toyota Vitz, Suzuki Swift, Mazda Demio, and Nissan Note.
What we like about the 2018 Honda Fit
Good fuel economy
Spacious and versatile cabin
Good driving dynamics
The engine is not very powerful
The 2018 Honda Fit is a stylish, reliable, spacious, and fuel economical hatchback that will be largerly appreciated by urban dwellers who commute a lot and folks with small families. Enthusiasts who value speed and performance will not find it in the Honda Fit for the primary objective of the manufacturers was to build a car that can move one from point A to point B using as little fuel as possible. Individuals on a tight budget are in a position to buy this car as its purchase price is affordable and not forgetting its service and maintenance cost which is also reasonable. Click here to download the 2018 Owner’s Manual.
We have developed a network of trusted dealers in Japan, South Africa, the UK, and Dubai who supply us with exceptionally high-quality vehicles. Eliminate middlemen and showroom costs by importing the car with us and saving up to KES 500,000. The import process takes 45-60 days from Japan & one week from South Africa and the car is delivered to your doorstep. Click here to choose the best varieties of Honda Fit.
