2018 Isuzu MUX Review
The Isuzu MUX has progressively gained traction in Kenya mainly because of its versatility, robust towing capacity, and off-road performance. It is a body-on-frame Sport Utility Vehicle based on the D-MAX.  Despite having all the benefits of an excellent car, it competes with the Toyota Fortuner, Ford Everest, Nissan Terra, and Mitsubishi Pajero Sport.
2018 Isuzu MUX front and side view
The first generation Isuzu MUX, codenamed RF, was manufactured from 2013 to 2020. The MUX is the outcome of a collaboration between GM and Isuzu. As a result, its platform was shared with the Chevrolet Trailblazer/Holden Colorado, which launched before MU-X.
The MUX had a facelift in 2017, which included integrated LED front and tail lights as well as improved interior quality with the addition of soft material.
The second edition of the MUX was conceptualized in 2020 and is currently in production. It shares the same platform as the third-generation D-Max, as well as the third-generation Mazda BT-50.
The 2018 Isuzu MUX is powered by two engine options, a 1.9 L RZ4E-TC (Diesel), and a 3.0 L 4JJ1-TCX (Diesel) which are coupled to a 6-speed Aisin automated transmission.
2018 Isuzu MUX Grades
  1. LS-M (4×4)- This grade comes with an engine immobilizer, cruise control, power steering, rear window demister, and AUX/USB input socket.
  2. LS-M (4×2)- This grade has an electronic brakeforce distribution, Bluetooth connectivity, a hill-holder, and an anti-lock braking system.
  3. LS-U (4×2)- This grade is fitted with a traction control system, power windows, a 12-volt power outlet, an MP3 Audio/CD player, an alarm system, and a multi-function control screen.
  4. LS-T (4×2)- This grade is equipped with rear privacy glass, a Radio CD with 6 speakers, power mirrors with indicators, emergency brake assist, climate control, and a reverse camera.
  5. LS-U (4×4)- This grade comes with chrome exterior mirrors, 17-inch alloy wheels, a chrome front grille, cruise control, and Bluetooth connectivity.
  6. LS-T (4×4)- This grade is fitted with an alarm system, a multi-function control screen, a reverse camera, climate control, and an electronic brake force distribution.
The 2018 Isuzu MUX’s interior is sleek and stylish.
In the first row, there is plenty of legroom and headroom. The seats are large enough to accommodate the thighs and can recline to a comfortable position. The second row is as impressive, with ample knee and headroom. Because of the limited leg and headroom, the third row of seats may be uncomfortable for adults, but it is great for children.
2018 Isuzu MUX first row
2018 Isuzu MUX second row
The 2018 Isuzu MUX has several kinds of compartment storage that can be used to store or keep items such as documents, keys, soft drinks, and so on.
There are two cupholders, a glovebox compartment, door pockets, and a center console in the first row. Two cupholders, jacket pockets, and door pockets can be found in the second row. Third-row passengers have access to a cup holder.
When the third row of seats is in place, the 2018 Isuzu MUX has 8.2 cubic feet of room. If additional space is required, the second and third rows of seats can be retracted.
The 2018 Isuzu MUX sports an imposing and robust appearance.
The grille is chrome-accented, and the Isuzu name is in between the horizontal chrome line. The headlamps are elegantly placed, and the LED daytime running lights add an extravagant flare. The lower fascia has fog lights and air vents.
To enable access, running boards are built on the side contour. The mirror housing features chrome accents, as does the frame line that extends from the A-pillar to the C-pillar. Roof rails on top of this SUV lend even more character to an already attractive vehicle.
The back end includes an electronically actuated tailgate, tail lamps, and turn signals.
2018 Isuzu MUX rear and side view
2018 Isuzu MUX Safety Features
The 2018 Isuzu MUX is fitted with multiple airbags, traction control, emergency braking, electronic brakeforce distribution, hill-holder, anti-lock braking assist, hill descent control, and cruise control.
2018 Isuzu MUX Fuel Consumption
2018 Isuzu MUX 1.9 L diesel engine consumption- 13.0 km/l on average
2018 Isuzu MUX  3.0 L diesel engine consumption- 12.1 km/l on average
2018 Isuzu MUX  Acceleration
2018 Isuzu MUX 1.9 L diesel engine accelerates from 0-100km/h in 13.3 secs
2018 Isuzu MUX 3.0 L diesel engine accelerates from 0-100km/h in 11.8 secs
The 2018 Isuzu MUX Fuel Tank Capacity: 65 liters
The 2018 Isuzu MUX has a ground clearance of 9.1 inches
The spare parts of the Isuzu MUX can be found in major towns. Some components like the suspension are costly.
The 2018 Isuzu MUX has a smooth and pleasant ride. The steering wheel is particularly responsive to road curvature, making the vehicle easy to manage. Its suspension system is well-tuned, so occupants do not feel jittery motions caused by uneven road surfaces. The interior is well-insulated against engine noise and vibrations from the road.
Its approach and departure angles enable it to effortlessly traverse difficult off-road terrain without difficulty or concern for damaging body components.
Furthermore, features such as cruise control, anti-lock braking, and hill descent control, among others, improve the vehicle’s stability.
2018 Isuzu MUX steering wheel and automatic gear shift
2018 Isuzu MUX wheel
The 2018 Isuzu MUX is known for its dependability. However, it has limitations, just like any other vehicle. Transmission issues are the most commonly reported by MUX owners. Regular servicing and maintenance are required to avoid these kinds of problems.
Refer to the Isuzu MUX buyer guide for a thorough dependability report. We also urge that you always follow the instructions in the owner’s manual.
Isuzu MUX Competitors: Toyota Fortuner, Ford Everest, Nissan Terra, and Mitsubishi Pajero Sport.
What we like about the 2018 Isuzu MUX
Beautiful cabin
Off-road prowess
A cramped third-row
Some variants are expensive
The 2018 Isuzu MUX can be used both in urban areas for commuting, and rural areas to tow trailers hauling freight like farm produce from one place to another. Folks on a limited budget may be unable to afford this car due to its high purchase price. Click here to choose the best variety of Isuzu MUX.
