2018 Nissan Note Review
The Nissan Note has undoubtedly established itself as one of the most sought-after subcompact hatchbacks because of its reliability, and affordability. Folks who are in the curb business will find it appealing primarily because of its excellent fuel economy. As much as it boasts the perks of a good car, It competes with the Toyota Ractis, Subaru Trezia, Honda Fit, Nissan March, Toyota Vitz, and Mazda Demio.
2018 Nissan Note front and side view
The first generation of the Nissan Note codenamed E11, went into production in 2004 and lasted until 2012. The second generation of the Note codenamed E12, began production in 2012 and continued until 2020. In 2017, Nissan unveiled a new hybrid powertrain. The Nissan Note is currently in its third generation, code-named E13.
The 2018 Nissan Note is available with four engine options, a 1.2L HR12DR (Petrol), 1.6L HR16DE (Petrol), 1.2L HR12DE (Hybrid), and a 1.5L K9K (Diesel) linked to either a 5-speed manual or Xtronic CVT. Click here to purchase the 2018 Nissan Note Buyer’s Guide.
2018 Nissan Note Grades
- AUTECH CVT- This grade boasts daytime running lights, electronic stability control, cruise control, and an anti-lock braking system.
- MEDALIST BLACK ARROW- This grade comes with power windows, a central locking remote control, power mirrors, and an adjustable steering wheel.
- MEDALIST- This grade is fitted with a brake assist, rear privacy glass, steering wheel with audio controls, and a manual air conditioner.
- NISMO CVT- This grade has a lip spoiler, 16-inch alloy wheels, climate control, fog lights, power mirrors, and electronic brake force distribution.
- S CVT- This grade comes with 16-inch alloy wheels, fog lights, a satellite navigation system, and a Radio/CD player.
- X CVT- This grade boasts daytime running lights, electronic stability control, cruise control, and an anti-lock braking system.
The cabin of the 2018 Nissan Note is minimalist and unadorned. There is ample head and leg room in the first row, and the seats may recline to fit any posture. The second row also provides enough headroom and kneeroom. However, taller passengers may feel a little bit cramped.
2018 Nissan Note first row
2018 Nissan Note second row
The 2018 Nissan Note features several storage spaces for holding or storing items like keys, drinks, and paperwork. There is a glovebox, a small center console, two cup holders, and door pockets in the first row. Two cupholders and door pockets are included in the second row.
The 2018 Nissan Note has a sizeable boot space that can accommodate small and medium-sized luggage. If more space is needed, the second-row seats can be retracted.
2018 Nissan Note boot space
The exterior design of the 2018 Nissan Note is svelte and polished. A V-shaped grille with some chrome elements is present on the front end. Just above the grille on hybrid variants is a blue line strip. The distinctive Nissan Note emblem is visible and aids in establishing its trademark. Its angular headlights and LED daytime running lights give it a contemporary appearance. This automobile has a dynamic appearance thanks to the air vents and fog lights on the lower fascia.
The rear features tail lights and turn signals. Its tailgate is electrically actuated and could be very convenient especially when your hands are full of cargo.
2018 Nissan Note front view
2018 Nissan Note rear and side view
2018 Nissan Note rear view
2018 Nissan Note Safety Features
The 2018 Nissan Note features multiple airbags, electronic brake force distribution, traction control, anti-lock braking system, and stability control.
2018 Nissan Note Fuel Consumption
2018 Nissan Note 1.2 L petrol engine consumption- 21.0 km/l on average
2018 Nissan Note 1.6 L petrol engine consumption- 19.2 km/l on average
2018 Nissan Note 1.2 L hybrid engine consumption- 23.1 km/l on average
2018 Nissan Note 1.5 L diesel engine consumption- 19.8 km/l on average
2018 Nissan Note Acceleration
2018 Nissan Note 1.2 L petrol engine accelerates from 0-100km/h in 14.4 secs
2018 Nissan Note 1.6 L petrol engine accelerates from 0-100km/h in 12.7 secs
2018 Nissan Note 1.2 L hybrid engine accelerates from 0-100km/h in 14.0 secs
2018 Nissan Note 1.5 L diesel engine accelerates from 0-100km/h in 13.6 secs
The 2018 Nissan Note Fuel Tank Capacity: 41 liters
The 2018 Nissan Note has a ground clearance of 6.1 inches which is below the required standard on Kenyan roads.
One of the advantages of owning a Nissan is that spare parts and other body components are readily available in metropolitan areas. The Note is no exception.
The 2018 Nissan Note provides a solid and comfortable ride. The steering wheel is quite simple to control and responds effectively to road curves. A well-tuned suspension system protects the occupants against abrupt movements. The cabin is well-insulated to keep road vibration and other undesirable noises out of the occupants’ ears. The brakes are up to the task as they are very strong and can bring this car to a complete stop in a matter of seconds, avoiding any mishaps.
The engine and transmission system work together to give a smooth start and sufficient acceleration. Other technologies incorporated into this car include anti-lock brakes, electronic brake force distribution, and traction control.
2018 Nissan Note steering wheel and gear shift
2018 Nissan Note cluster meter
The 2018 Nissan Note is regarded as a reliable vehicle. The Note should not be driven off-road due to the risk of damaging its body parts due to its low ground clearance. The most common complaint cited by Note owners is transmission malfunction. To avoid such issues, regular servicing and maintenance are essential.
Nissan Note Competitors: Toyota Ractis, Subaru Trezia, Honda Fit, Nissan March, Toyota Vitz, and Mazda Demio.
What we like about the 2018 Nissan Note
Reliable
The 2018 Nissan Note can make a good choice for city dwellers who commute to work because of its outstanding fuel efficiency. Folks with small households will find this car very appealing. Individuals on a tight budget can afford to buy this car since its purchasing price together with service and maintenance are not costly. Click here to choose the best variety of Nissan Note.
