2018 Range Rover Velar Review
The Range Rover Velar is a sub-brand of Range Rover that has continually been in demand in the Kenyan market because of its versatility, and most importantly its advanced infotainment system which basically controls almost everything in this car. It competes with Mercedes Benz GLE, Mercedes Benz GLC, Porsche Macan, Audi Q7, and BMW X5.
2018 Range Rover Velar front and side view
The Range Rover Velar was unveiled to the public in 2017. Its new design language highlights sportiness and on-road capabilities, with fluid body lines.
The 2018 Range Rover Velar is available with three engine options: 2.0 L (Petrol), 2.0 L (Diesel),  and 3.0 L (Petrol) all coupled to an 8-speed automatic transmission.
2018 Range Rover Velar Grades
  1. P250 Base- This grade comes with an automatic equalizer, Turn-By-Turn navigation directions, Real-Time traffic display, streaming audio, and 10 GB internal memory.
  2. P250 S- This grade has speed-compensated volume control, external memory control, window grid, and roof mount diversity antenna.
  3. D180 S- This grade is fully equipped with a Meridian signature sound system, SSD navigation, Touch Pro Duo, and Bluetooth connectivity.
  4. P250 SE R-Dynamic- This grade boasts a wing spoiler, automatic high beams, body-colored handles, and an interior lock disable.
  5. D180 SE R-Dynamic- This grade has a Meridian sound system, SSD navigation system, Bluetooth connectivity, USB ports, and an 825 watts premium amplifier.
  6. P380 S- This grade is fully equipped with an automatic equalizer, window grid, streaming audio, and a digital processor.
  7. P250 HSE R-Dynamic- This grade boasts a leather steering wheel, Satin chrome gearshift paddles, a lockable cooled glovebox, and a 4-zone climate control.
  8. D180 HSE R-Dynamic- This grade is fitted with a grille surround in Narvik black, hood vent & air curtain inserts, fender &door finisher blade, and a tailgate lettering.
  9. P380 SE R-Dynamic- This grade boasts 21-inch alloy wheels, adaptive cruise control,  park assist, USB input, and Bluetooth connectivity.
  10. P380 HSE R-Dynamic- This grade incorporates a lane keep assist, traffic sign recognition, blind spot monitoring, and a head-up display.
  11. P380 First Edition- This grade is fitted with an automatic equalizer, streaming audio, push-button start, a navigation system, and a 4-zone climate control.
The 2018 Range Rover Velar is a  crossover SUV that combines top-tier luxury with hassle-free utility.
The first row boasts lots of headroom and legroom, as well as seats that snuggle you in nicely.
The headroom and knee room in the second row are also outstanding, with reclining seats creating more space to sprawl out comfortably.
2018 Range Rover Velar first row
2018 Range Rover Velar second row
The 2018 Range Rover Velar has two cupholders, a lockable glovebox compartment, and door pockets in the first row. The second row includes two cupholders on the armrest, as well as door and jacket pockets.
2018 Range Rover Velar cabin compartments
The 2018 Range Rover Velar offers 34.4 cubic feet of space when all seats are in use and 70.1 cubic feet of space with the rear seats folded.
2018 Range Rover Velar boot space
The front end of the 2018 Range Rover Velar has a honeycomb-like grille with the Land Rover insignia fastened to it. The latest incarnation of Range Rover’s distinct design language is set off by slim LED headlights.
The characteristic deployable flash door handles allow the car to have a surprisingly low drag coefficient and hence reduce fuel consumption.
A small LED tail lamp and turn signals can also be seen at the rear of the vehicle, which has a sloping roofline.
2018 Range Rover Velar front view
2018 Range Rover Velar rear and side view
2018 Range Rover Velar rear view
2018 Range Rover Velar Safety Features
The 2018 Range Rover Velar features SRS Airbags, Curtain airbags, DCS and TCS, ABS, Electronic Stability Control, Pre-crash Safety System, Radar Cruise Control, Blind Spot Detection, Pedestrian Warning, Lane Departure Alert, Frontal Collision Warning, Automatic High Beam, Run Flat tires, Active Roll Stabilization, and Electronic Damping Control.
2018 Range Rover Velar Fuel Consumption
2018 Range Rover Velar 2.0 L petrol engine consumption- 10.1 km/l on average
2018 Range Rover Velar 2.0 L diesel engine consumption- 11.2 km/l on average
2018 Range Rover Velar 3.0 L petrol engine consumption- 10.6 km/l on average
2018 Range Rover Velar Acceleration
2018 Range Rover Velar 2.0 L petrol engine accelerates from 0-100km/h in 7.1 secs
2018 Range Rover Velar 2.0 L diesel engine accelerates from 0-100km/h in 6.8 secs
2018 Range Rover Velar 3.0 L petrol engine accelerates from 0-100km/h in 6.0 secs
2018 Range Rover Velar Fuel Tank Capacity: 62 liters
The 2018 Range Rover Velar has a ground clearance of 8.4 inches.
Service parts are fairly priced and available in major towns in Kenya. Body parts are expensive and mostly available in Nairobi
The 2018 Range Rover Velar is a delightful and comfortable vehicle to drive. The steering is responsive, and the brakes are powerful. All models encompass adjustable suspension, which allows this Land Rover to glide softly over bumps and potholes in the road. This mechanism also helps to keep the crossover SUV steady when turning. An adaptive air suspension is available, which further improves the SUV’s ride quality.
The Velar isn’t as good off-road as its Range Rover and Range Rover Sport siblings, but it’s still among the best in its class. Range Rover Velar’s Terrain Response technology is standard.
2018 Range Rover Velar steering wheel
2018 Range Rover Velar automatic gear shift
2018 Range Rover Velar wheel
The 2018 Range Rover Velar is a highly reliable vehicle. One of the most typical issues with this crossover SUV is the transmission. According to some owners, the Velar is slow to shift gears and hesitant while accelerating.
This vehicle requires regular maintenance as well as repairs.
Refer to the Ranger Rover Velar buyer guide for a thorough dependability report. We also urge that you always follow the instructions in the owner’s manual.
Range Rover Velar Competitors: Mercedes Benz GLE, Mercedes Benz GLC, Porsche Macan, Audi Q7, and BMWX5.
What we like about the 2018 Range Rover Velar
Distinctive styling in and out
Strong V6 engine
Upscale interior
Some variants are very costly
The 2018 Range Rover Velar stands out for its rakish appearance and opulent interior. Individuals with limited funds, on the other hand, may find it difficult not only to purchase this car but also to maintain it. Click here to choose the best variety of Range Rover Velar.
2018 Range Rover Velar side view
