2018 Subaru Exiga Review
The Subaru Exiga has been in existence for a decade and 2018 marks its discontinuation by the Japanese Automaker. Several Kenyans were appealed to it due to its stunning exterior design that could coat attention at any given time, spacious cabin that highly favored folks with large households, versatility, and reliability. As much as it has the perks of an excellent car, it was up against the Toyota Wish, Mazda Premacy, Honda Stream, and Nissan Lafesta.
2018 Subaru Exiga front view
The Subaru Exiga launched its production in 2008 and has since undergone modifications and improvements to be what it is now. It was built to replace the Subaru Traviq which had also a seven-seating configuration. Its exterior design is quite similar to the Legacy apart from the rear-end styling.
The 2018 Subaru Exiga comes with one engine option, a 2.5 L FB25 (Petrol) linked to a Linear-tronic CVT transmission.
2018 Subaru Exiga grades
  1. Subaru Exiga 2.5i Eyesight- This entry grade comes with a central door lock, power-assisted steering, power mirrors, parking sensors, a reverse camera, a 12-volt power outlet, and an anti-lock braking system.
  2. Subaru Exiga Modern Style 2.5- This grade features an AM/FM Radio, CD Player, Bluetooth connectivity, power windows, electronic brake force distribution, traction control, and a lane departure warning.
  3. Subaru Exiga X Break 2.5- This grade comes fitted with a DVD/Radio player, Subaru Eye-sight technology, privacy glass, a panoramic sunroof, a centralized door lock, and traction control.
The 2018 Subaru Exiga has a beautiful interior with a seven-seat theater-like configuration. The first row offers plenty of legroom and headroom. The second row is impressive as well with sufficient knee room and headroom. The third-row seats are only suitable for children due to their limited headroom and legroom.
2018 Subaru Exiga first row
2018 Subaru Exiga view from second row
The 2018 Subaru Exiga features numerous storage compartments intended to improve the comfort of the occupants. The first row has two cupholders, a center console, door panel storage, and a glove box compartment. The second row includes jacket pockets, two cupholders, and door pockets. Passengers in the third-row seat have access to cupholders.
The 2018 Subaru Exiga has an ample cargo room that can hold small and medium-sized luggage. If more space is required, the second and third-row seats can be folded.
The 2018 Subaru Exiga has a refined and elegant exterior design that will for sure coat attention wherever it traverses. The front end is distinguished by a bold chrome-accented grille adorned with the prominent Subaru logo to stamp its authority. A hood scoop is well positioned on the hood which aids in cooling the engine and at the same time depicting its aggressiveness. LED daytime running lights and the headlights give it a contemporary appearance. Fog lights and air vents can be spotted at the lower fascia. Depending on the owner’s preference, a lip spoiler with carbon fiber embellishments can be incorporated at the lower bumper to enhance its sportiness while at the same time improving the aerodynamics.
Its side profile is very conservative and has contours that are not easily noticeable. It has a longer wheelbase which in return results in a spacious cabin. The rear end is fitted with tail lights and turn signals and its tailgate is electronically actuated which could be very convenient especially when your hands are full of cargo. A roof spoiler is well positioned at the back to complete the Exiga’s beautiful look.
2018 Subaru Exiga front and side view
2018 Subaru Exiga rear and side view
2018 Subaru Exiga rear view
2018 Subaru Exiga Safety Features
The 2018 Subaru Exiga features traction control, stability control, an anti-locking braking system, multiple airbags, and electronic brake force distribution. It also incorporates Starlink Safety Plus telematics system which includes emergency assistance and automatic collision notification.
2018 Subaru Exiga Fuel Consumption
2018 Subaru Exiga 2.5 L petrol engine consumption- 13.1 km/l on average
2018 Subaru Exiga Acceleration
2018 Subaru Exiga 2.5 L petrol engine accelerates from 0-100km/h in 8.0 secs
The 2018 Subaru Exiga Fuel Tank Capacity: 65 liters
Ground Clearance: The 2018 Subaru Exiga has a ground clearance of 6.5 inches which is within the required standard of 6.5 inches on Kenyan road.
Service parts are available and fairly priced in Kenya. Body parts on the other hand are expensive and mostly available from Subaru Kenya.
The 2018 Subaru Exiga has a sturdy and comfortable ride. Its steering wheel is power-assisted so It adapts very well to road curvature and also makes overtaking on highways easier. The suspension system is rigid enough to protect passengers from experiencing any kind of jarring movements. Its cabin is well-insulated to protect passengers from unwanted noise picked from road surfaces or even the engine. The engine works in tandem with the transmission system to deliver a smooth start and good acceleration. Even though it has a low center of gravity, it is advisable to reduce speed when approaching tight corners.
As much as it is within the recommended standard on Kenyan roads in regards to ground clearance, its approach and departure angles limit it from traversing extreme off-road terrains. To improve its agility and stability, the Exiga has incorporated stability control, traction control, and electronic brake force distribution that guarantees occupants a safe ride.
2018 Subaru Exiga steering wheel
2018 Subaru Exiga engine
2018 Subaru Exiga wheel
The 2018 Subaru Exiga is considered a reliable car. Its ground clearance is within the required threshold on Kenyan roads but exploiting extreme off-road terrains can damage its body components. Excessive oil consumption and transmission issues are the common troubles reported by Exiga owners. Regular service and maintenance are required to avoid experiencing such kind of issues.
Refer to the Subaru Exiga buyer guide for a thorough reliability report. We also urge that you always follow the instructions in the owner’s manual.
Subaru Exiga Competitors: Toyota Wish, Mazda Premacy, Honda Stream, and Nissan Lafesta.
What we like about the 2018 Subaru Exiga
Spacious cabin
Excellent visibility
Agile handling
Its ground clearance is not high enough to exploit extreme off-road
The 2018 Subaru Exiga is a stylish, versatile, and practical vehicle that matches the preference of different buyers whether in the metropolis where it can be used to commute to work and go for some shopping, or in rural areas where it can be used to haul cargo for instance produce from the farm. People with large households will appreciate its spacious cabin and seating configuration. As much as the majority of people would love to own this car, its high purchase price limits individuals on a tight budget from owning it.
Click here to choose the best variety of Subaru Exiga.
2018 Subaru Exiga side view
