2018 Toyota Sienta Review
The Toyota Sienta is a mini MPV that has made great strides in the Kenyan market due to its reliability, excellent fuel economy, and durability. It is positioned below the Voxy/Noah and above the Roomy in Toyota's MPV range. The name "Sienta" is derived from the Spanish word "siete" meaning "seven" (referring to its maximum passenger capacity) and the English word "entertain". As much as it is considered a good car, it is up against the Honda Freed, Honda Fit Shuttle, VW Touran, and Peugeot Partner.
2018 Toyota Sienta front view
The first generation Toyota Sienta, known as the XP80, was introduced in 2003 and was in production until 2015. The Sienta was redesigned in 2006, with new colors such as apple green and metallic blue added.
Toyota Sienta’s second generation designated XP170, went into production in 2015 and continued up to 2022. It abandoned its predecessor’s boxy style in favor of an updated exterior design inspired by the shape of a trekking shoe. When compared to prior generations, interior space was also increased.
The Toyota Sienta is based on the NBC platform, which is also used by the Vitz, Platz, Porte, and other vehicles. The 2018 Toyota Sienta is available with two engines, a 1.5-liter 1NZ-FE (petrol) and a 1.5-liter 1NZ-FXE (hybrid) connected to a CVT and an eCVT (electronic continuously variable transmission).
2018 Toyota Sienta Grades
  1. FUNBASE G 5 Passengers- This grade comes with privacy glass, electronic brakeforce distribution, power windows, an Isofix bar, and an anti-lock braking system.
  2. FUNBASE X 5 Passengers- This grade has traction control, an air conditioner, a Radio/DVD player, a back wiper, mud-flaps, keyless entry, and fog lights.
  3. G 6 Passengers- This grade is equipped with a collision mitigation system,  an electronic brake force distribution, and an automatic air conditioner.
  4. G 7 Passengers- This grade boasts a hill-assist control system, an air conditioner, 4 speakers, a damping control system, and an alarm system.
  5. G CUERO 6 Passengers- This grade is equipped with a rear window defroster, a sunroof, AM/FM Radio, and a navigation system.
  6. G CUERO 7 Passengers- This grade has a power slide door, power mirrors, privacy glass, a CD player, and an electronic brake force distribution.
  7. X 6 Passengers- This grade is fitted with power steering, an anti-lock braking system, and an air conditioner.
  8. X 7 Passengers- This grade comes with an alarm system, AM/FM Radio, a power slide door, a collision mitigation system, and an Isofix bar.
The interior of the 2018 Toyota Sienta is simple.
There is plenty of headroom and legroom in the first row, and the seats can be reclined. The second row is not disappointing because there is plenty of room for the knees and head. The third-row seats are only suitable for kids due to minimal leg and headroom.
2018 Toyota Sienta first row
2018 Toyota Sienta second row
2018 Toyota Sienta third row
The 2018 Toyota Sienta boasts several storage compartments to enhance passenger comfort. The front row includes a small central console, a glove box, two cup holders, and door pockets. There are two cupholders and door pockets in the second row. Third-row passengers have access to cup holders.
The 2018 Toyota Sienta has an adequate cargo compartment for small and medium-sized goods. The second and third rows of seats can be retracted if more space is needed.
2018 Toyota Sienta boot space
The exterior of the 2018 Toyota Sienta is sporty and refined.
The large grille and Toyota emblem dominate the front of the car, while the headlights give it a modern look. The lower fascia incorporates fog lights and air vents. The side profile includes sliding doors that open wide to make it easier to get in and out of the rear seats. The back end has tail lights and indicators.
2018 Toyota Sienta front and side view
2018 Toyota Sienta rear and side view
2018 Toyota Sienta rear view
2018 Toyota Sienta Safety Features
The 2018 Toyota Sienta features an anti-lock braking system, multiple airbags, electronic brakeforce distribution, a damping control system, a collision mitigation system, and brake assist.
2018 Sienta Fuel Consumption
2018 Toyota Sienta 1.5 L petrol engine consumption- 20.0 km/l on average
2018 Toyota Sienta 1.5 L hybrid engine consumption- 26.6 km/l on average
2018 Toyota Sienta Acceleration
2018 Toyota Sienta 1.5 L petrol engine accelerates from 0-100km/h in 12.2 secs
2018 Toyota Sienta 1.5 L hybrid engine accelerates from 0-100km/h in 12.4 secs
The 2018 Toyota Sienta Fuel Tank Capacity: 42 liters
The 2018 Toyota Sienta has a ground clearance of 5.7 inches which is below the required standard on Kenyan roads.
One of the advantages of owning a Toyota is that spare parts and other body components are easy to come by because they share many parts. The Sienta is no exception.
The 2018 Toyota Sienta offers a comfortable ride. Its handling is top-notch. Its compact size combined with a small turning radius makes it very easy to maneuver. The steering is light but firm. Visibility out of the car is good.
The suspension system is solid, despite the use of a simpler torsion beam rear suspension. The front has a MacPherson strut suspension. Ventilated and solid disc brakes at the front and rear help to bring the car to a complete stop in an emergency.
Anti-lock brakes and a damping control system are also incorporated in this vehicle to enhance stability.
2018 Toyota Sienta steering wheel
2018 Toyota Sienta automatic gear shift
2018 Toyota Sienta wheel
The 2018 Toyota Sienta has an exceptional reliability rating because of its good fuel economy. It is strongly advised not to drive off-road because of its low ground clearance, since you could damage its body components. Transmission issues are the most frequently reported by Sienta owners. To keep the car in great condition, it must be serviced and maintained regularly.
Refer to the Toyota Sienta buyer guide for a thorough dependability report. We also urge that you always follow the instructions in the owner’s manual.
Toyota Sienta Competitors: Honda Freed, Honda Fit Shuttle, VW Touran, and Peugeot Partner.
What we like about the 2018 Toyota Sienta
Reliable
Not very Expensive
The 2018 Toyota Sienta is an excellent vehicle for people with large families. Because of its outstanding fuel efficiency, one can get into a cab business and maximize revenue. Individuals on a limited budget can make some compromises to purchase this car because service and maintenance are not costly. Click here to download a copy of the 2018 Toyota Sienta Owner’s Manual.
Click here to choose the best variety of Toyota Sienta.
