2019 Isuzu MUX Review
The Isuzu MUX has made a name for itself in the Kenyan market owing to its adaptability, powerful towing capacity, and off-road prowess. It's a body-on-frame Sport Utility Vehicle based on the D-MAX. The abbreviation MU-X stands for Multi Utility- Extreme. Despite having all of the advantages of an outstanding vehicle, it competes with the Toyota Fortuner, Ford Everest, Nissan Terra, and Mitsubishi Pajero Sport.
2019 Isuzu MUX front and side view
From 2013 through 2020, the first generation Isuzu MUX, codenamed RF, was produced. The MUX is the result of a collaboration between General Motors and Isuzu. As a result, it shared its platform with the Chevrolet Trailblazer/Holden Colorado, which debuted before MU-X.
In 2017, the MUX received a facelift that included integrated LED front and rear lighting as well as better interior quality with the inclusion of soft material.
The MUX’s second version was developed in 2020 and is currently in production. It is built on the same platform as the third-generation D-Max and the Mazda BT-50.
The 2019 Isuzu MUX is powered by two engine options, a 1.9 L RZ4E-TC (Diesel), and a 3.0 L 4JJ1-TCX (Diesel) which are coupled to a 6-speed Aisin automated transmission.
2019 Isuzu MUX Grades
- LS-M (4×4)- This grade comes with an engine immobilizer, cruise control, power steering, rear window demister, and AUX/USB input socket.
- LS-M (4×2)- This grade has an electronic brakeforce distribution, Bluetooth connectivity, a hill-holder, and an anti-lock braking system.
- LS-U (4×2)- This grade is fitted with a traction control system, power windows, a 12-volt power outlet, an MP3 Audio/CD player, an alarm system, and a multi-function control screen.
- LS-T (4×2)- This grade is equipped with rear privacy glass, a Radio CD with 6 speakers, power mirrors with indicators, emergency brake assist, climate control, and a reverse camera.
- LS-U (4×4)- This grade comes with chrome exterior mirrors, 17-inch alloy wheels, a chrome front grille, cruise control, and Bluetooth connectivity.
- LS-T (4×4)- This grade is fitted with an alarm system, a multi-function control screen, a reverse camera, climate control, and an electronic brake force distribution.
The interior of the 2019 Isuzu MUX is modern and attractive.
There is ample legroom and headroom in the first row, and the seats can recline to a comfortable position. The second row is also impressive, with plenty of leg and headroom. The third row of seats may be unpleasant for adults because of the limited leg and headroom, but it is ideal for kids.
2019 Isuzu MUX first row
2019 Isuzu MUX second row
The 2019 Isuzu MUX includes a variety of compartment storage options for storing or keeping items such as paperwork, keys, soft drinks, and so on.
In the first row, there are two cupholders, a glovebox compartment, door pockets, and a center console. The second row has two cupholders, jacket pockets, and door pockets. A cup holder is available to third-row occupants.
With the third row in place, there’s storage space beneath the floor, plus additional storage that adds up to 8.2 cubic feet of cargo capacity. Fold the third row away and it jumps to 29.5 cubic feet, while folding the third and second rows away expands the space to 64.6 cubic feet.
The 2019 Isuzu MUX has a commanding and solid appearance.
The grille is emphasized with chrome, and the Isuzu name is in between the horizontal chrome line. The headlamps are positioned beautifully and the LED daytime running lights provide an air of refinement. Fog lights and air vents are located on the lower fascia.
Running boards are installed on the side contour to allow access. The mirror housing, as well as the frame line that runs from the A-pillar to the C-pillar, have chrome highlights. Roof rails on top of this SUV add character to an already appealing vehicle.
The rear end is equipped with an electronically controlled tailgate, tail lamps, and turn signals.
2019 Isuzu MUX front view
2019 Isuzu MUX rear and side view
2019 Isuzu MUX rear view
2019 Isuzu MUX Safety Features
The 2019 Isuzu MUX is fitted with multiple airbags, traction control, emergency braking, electronic brakeforce distribution, hill-holder, anti-lock braking assist, hill descent control, and cruise control.
2019 Isuzu MUX Fuel Consumption
2019 Isuzu MUX 1.9 L diesel engine consumption- 13.2 km/l on average
2019 Isuzu MUX 3.0 L diesel engine consumption- 12.4 km/l on average
2019 Isuzu MUX Acceleration
2019 Isuzu MUX 1.9 L diesel engine accelerates from 0-100km/h in 13.2 secs
2019 Isuzu MUX 3.0 L diesel engine accelerates from 0-100km/h in 11.6 secs
The 2019 Isuzu MUX Fuel Tank Capacity: 65 liters
The 2019 Isuzu MUX has a ground clearance of 9.1 inches
The spare parts of the Isuzu MUX can be found in major towns. Some components like the suspension are costly.
The ride and handling of the 2019 Isuzu MU-X are two of its true standout traits in and around town. Its independent suspension at the front and a coil-spring system with gas shock absorbers and a stabilizer bar at the rear absorb bumps superbly. This combination stabilizes the rear over-speed humps and controls lateral movement while driving at high speeds on corrugated roads.
The braking system is up to the duty of slowing down the MU-X, and the four-wheel-disc configuration is supported by Anti-Lock Brakes with Electronic Brakeforce Distribution and Emergency Brake Assist.
The steering wheel responds well to road curvature and is easy to handle.
2019 Isuzu MUX automatic gear shift
2019 Isuzu MUX wheel
The 2019 Isuzu MUX has a reputation for dependability. It does, however, have limitations, just like any other vehicle. Transmission problems are the most typical complaints from MUX owners. To avoid such issues, regular servicing and maintenance are essential.
Refer to the Isuzu MUX buyer guide for a thorough dependability report. We also urge that you always follow the instructions in the owner’s manual.
Isuzu MUX Competitors: Toyota Fortuner, Ford Everest, Nissan Terra, and Mitsubishi Pajero Sport.
What we like about the 2019 Isuzu MUX
Impressive ride and handling
Off-road capability
No Apple car play or Android connectivity
The 2019 Isuzu MUX delivers on its promises of superior towing capacity, off-road prowess, and versatility. Because it is categorized as a midsize SUV, its fuel efficiency is good, and people living in suburban as well as rural places can use it for commuting. Click here to choose the best variety of Isuzu MUX.
2019 Isuzu MUX side view
