2019 Mitsubishi L200 Review
The Mitsubishi L200's presence in the Kenyan market is already being felt as you can barely cover a long distance without spotting one. The 2019 model has nearly everything improved to a degree from its exterior styling to its engine performance, and it still does not compromise on its off-road capabilities and towing capacity. The Triton as is otherwise known in other markets, provides a good balance between power and fuel efficiency, hence endowing it to a number of buyers. As much as it is considered a durable and reliable pickup, it is up against the likes of Toyota Hilux, Ford Ranger, Volkswagen Amarok, Nissan Navara, Isuzu D-MAX, and Nissan Hardbody.
2019 Mitsubishi Delica front and side view
The first generation of the Mitsubishi L200 started its production back in 1978 and continued up to 1986. The second version of the L200 was manufactured from 1986 to 1996. From 1996 to 2005, the L200’s third generation was in production. The fourth iteration of the L200 commenced its production in 2005 and continued up to 2015. The fifth generation was in production from 2015 to 2023. In this period, the L200 underwent major facelifts that saw it have a new, sleek, and modern exterior styling. The Mitsubishi L200 is currently in its sixth iteration.
The 2019 Mitsubishi L200 comes with two engine options, a 2.4 L (Diesel), and 2.5 L (Diesel) linked to either a 5/6-speed manual transmission or a 5/6-speed automatic transmission. Click here to purchase the 2019 Mitsubishi L200 Buyer’s Guide.
Mitsubishi L200 Body Configurations
- Single Cabin
- Extended Cabin
- Double Cabin
2019 Mitsubishi L200 grades
- Mitsubishi L200 GLX- This grade comes with Bluetooth connectivity, a centralized door lock, a 12-volt power outlet, chrome door handles, and power mirrors.
- Mitsubishi L200 GLX-R- This grade features multiple airbags, blind spot monitoring, traction control, an anti-lock braking system, a hill start assist, power windows, and an AM/FM Radio.
- Mitsubishi L200 GLS- This grade has parking sensors, chrome door handles, chrome-accented mirror caps, climate control, stability control, a lane departure warning, and a rearview camera.
- Mitsubishi L200 Exceed- This grade is fitted with blind spot monitoring, Bluetooth connectivity, smartphone integration, privacy glass, LED daytime running lights, and a power-assisted steering wheel.
The 2019 Mitsubishi L200 has a simple and plain cabin that is somewhat pleasing. The first row boasts plenty of legroom and headroom and its seats can be reclined to match a desired preference. The second row of the double cabin has sufficient knee room and headroom. Taller individuals might find the second row crampy. The second row of the extended cab is suitable for children as adults will find it unpleasant to sit in owing to its limited space for the head and legs.
2019 Mitsubishi L200 first row
2019 Mitsubishi L200 second row
The 2019 Mitsubishi L200 has numerous storage compartments that are intended to improve the comfort of occupants. The single cab features door panel storage a small center console, two cupholders, and a glove box.
The Extended cab has two cupholders, a center console, door pockets, and a glove box in the first row. The second row includes door panel storage only.
The double cabin’s first row has two cupholders, a glove box compartment, door panel storage, and a center console. Its second row is fitted with jacket pockets, door pockets, and two cupholders mounted on the armrest.
The 2019 Mitsubishi L200 comes with three body configurations. The single cab, extended cab, and double cab have a spacious load area that can accommodate tons of freight.
2019 Mitsubishi L200 boot space
The 2019 Mitsubishi L200 has an upscale, rugged, and refined look. The front end is adorned with a chrome-accented grille with the Mitsubishi’s “shield-like design” insignia. Its hood has nicely done contours that complement its design elements. The LED daytime running lights and the headlights give the L200 a sophisticated appearance. The lower bumper houses fog lights and air vents.
This pickup’s ruggedness continues to the side profile as the fenders depict a muscular look that blends very well with the 19-inch alloy wheels that are good for extreme off-road driving. Roof rails and the roof spoiler make this pickup to be more aesthetically pleasing.
The rear end has a big tailgate that is opened and closed manually. Tail lights and turn signals complete the overall look of the Mitsubishi L200. This pickup furthermore blends well with after-market modifications, so folks who love going for extreme off-road drives can replace the plastic front and rear bumpers with a bull bar to protect its body components. The suspension system can also be swapped to raise the clearance of the pickup.
2019 Mitsubishi L200 rear and side view
2019 Mitsubishi L200 Safety Features
The 2019 Mitsubishi L200 features multiple airbags, traction control, lane keep assist, traction control, cruise control, anti-lock braking system, electronic brake force distribution, brake assist, and blind spot monitoring.
2019 Mitsubishi L200 Fuel Consumption
2019 Mitsubishi L200 2.4 L diesel engine consumption- 13.0 km/l on average
2019 Mitsubishi L200 2.5 L diesel engine consumption- 12.4 km/l on average
2019 Mitsubishi L200 Acceleration
2019 Mitsubishi L200 2.4 L diesel engine accelerates from 0-100km/h in 11.7 secs
2019 Mitsubishi L200 2.5 L diesel engine accelerates from 0-100km/h in 10.8 secs
The 2019 Mitsubishi L200 Fuel Tank Capacity: 75 liters
Ground Clearance: The 2019 Mitsubishi L200 has a ground clearance of 7.8 inches.
Mitsubishi L200 spares, especially body parts are not as easily available in Kenya and they are sometimes expensive. Service parts are fairly affordable and easy to find within Nairobi and other major towns.
The 2019 Mitsubishi L200 rides smoothly and comfortably. Its slanting hood gives occupants superb views of the oncoming traffic. Its steering wheel adapts very well to road bends making it easy and simple to control the pickup. The suspension system strikes a proper balance between comfort and functionality. When traversing off-road terrains, it cushions passengers from experiencing startling movements.
The L200 encompasses a selectable 4WD system that enables it to exploit any kind of terrain whether on mud, gravel, or sand without getting stuck. Its approach and departure angles not forgetting its high ground clearance allow it to be driven on any kind of terrain without the risk of damaging its body components.
The brakes are very robust and come in handy when trying to avoid any kind of collision as it can bring this pickup to a complete halt in a matter of seconds. The cabin is well insulated to prevent outside noise likely from the engine or noises picked from rough road surfaces from making the occupants feel uncomfortable. Some of the technologies incorporated in the 2019 Mitsubishi L200 to improve its stability include an anti-lock braking system, hill start assist, electronic brake force distribution, and a blind spot monitor.
2019 Mitsubishi L200 steering wheel & automatic gear shift
The 2019 Mitsubishi L200 is considered as a reliable vehicle. It has a high ground clearance that enables it to cruise on any kind of terrain. However, just like any other pickup, the L200 is not immune to problems. Fuel filter fault, head gasket fault, and leaf springs crack are the most commonly reported troubles in this vehicle. Regular service and maintenance are required to avoid experiencing such kind of issues.
Mitsubishi L200 Competitors: Toyota Hilux, Ford Ranger, Volkswagen Amarok, Nissan Navara, Isuzu D-MAX, and Nissan Hardbody.
What we like about the 2019 Mitsubishi L200
Off-road capability
Excellent towing capacity
Fuel efficiency
Some variants are very expensive
The 2019 Mitsubishi L200 is living up to its name of a reliable, durable, and versatile pickup with excellent off-road capabilities, as well as good towing capacity. It offers a superb balance of power and fuel efficiency something both the urban dwellers and off-road enthusiasts would want in a vehicle of its stature. However, due to its high purchase price, folks with a tight budget may not be able to afford to buy this pickup. Click here to download the 2019 Mitsubishi L200 Owner’s Manual.
We have developed a network of trusted dealers in Japan, South Africa, the UK, and Dubai who supply us with exceptionally high-quality vehicles. Eliminate middlemen and showroom costs by importing the car with us and saving up to KES 500,000. The import process takes 45-60 days from Japan & one week from South Africa and the car is delivered to your doorstep. Click here to choose the best varieities of Mitsubishi L200.
