2019 Mitsubishi Mirage Review
The Mitsubishi Mirage is continuing to cement its position as one of the best-selling compact hatchbacks in Kenya. It is designed to appeal to budget-conscious customers who are looking for a basic and affordable mode of transportation. Its stellar fuel economy has made it to be embraced in the transport industry not only as a daily driver but also as a taxi. People who value performance may not find it in the Mirage for it is more of a practical and economical car. It competes with the Honda Fit, Nissan March, Suzuki Alto, and Daihatsu Mira.
2019 Mitsubishi Mirage front and side view
The Mitsubishi Mirage made its debut in 1978 and remained in production until 2003 when its production was paused. In 2012, the manufacturers resumed the production of the Mirage which replaced the Mitsubishi Colt. When designing the Mirage, affordability, and fuel efficiency were the core objectives of the manufacturers.
The 2019 Mitsubishi Mirage is available with only one engine option, a 1.2 L (Petrol) connected to either a 5-speed manual transmission or CVT.
 2019 Mitsubishi Mirage Grades
  1. Mitsubishi Mirage ES- This grade has parking distance sensors, electronic brake force distribution, climate control, Bluetooth connectivity, a multi-function display screen, and brake assist.
  2. Mitsubishi Mirage SE- This grade has a 12-volt power outlet, power mirrors, body-colored door handles, active stability control, a reverse camera, multiple airbags, an Isofix bar, a low tire pressure indicator, and an AM/FM Radio.
  3. Mitsubishi Mirage GT- This grade encompasses four speakers, a CD player, remote audio controls, brake assist, keyless entry, power windows, a 12-volt power output, and parking distance sensors.
  4. Mitsubishi Mirage RF- This grade is equipped with a Rockford Fosgate audio system, climate control, push-button start, keyless entry, and a power-assisted steering wheel.
  5. Mitsubishi Mirage LE- This grade boasts Apple Car Play, Android Auto, a driver’s seat armrest, heated front seats, a leather-wrapped steering wheel, a six-speaker sound system, and power windows.
The 2019 Mitsubishi Mirage has a basic and plain cabin that is somehow attractive. The first row boasts plenty of legroom and headroom. The second row is pretty impressive for average-sized people. Taller occupants might find it unpleasant due to a limited knee room.
2019 Mitsubishi Mirage first row
2019 Mitsubishi Mirage second row
The 2019 Mitsubishi Mirage has numerous storage compartments that are designed to improve the comfort of occupants by storing or holding items like soft drinks, beverages, paperwork, and other commodities. The first row has a glove box compartment, three cupholders, and door panel storage. Passengers in the second row have access to jacket pockets and door pockets.
2019 Mitsubishi Mirage glove box compartment
The 2019 Mitsubishi Mirage boasts an ample cargo area that can accommodate small and medium-sized goods. The rear seats can be retracted to create more space.
The 2019 Mitsubishi Mirage depicts a stylish and sophisticated appearance. Its refined exterior design largely appeals to the young clientele. The front end bears a nicely curved grille with chrome embellishments as the Mitsubishi badge is adorned on it. The Mirage look is enhanced by the headlights and LED daytime running lights. Because of its slanting bonnet, the driver as well as other occupants of the Mirage have an excellent view of the oncoming traffic. The lower fascia is fitted with air vents and fog lights that come in handy especially when you are driving in dusty areas or mist-prone surroundings.
The side profile features contours that can be barely seen from a distance unless you move closer to the vehicle. The door handles as well as the mirror caps are body-colored. The rear end is incorporated with a roof spoiler that adds some allure and flair to the car, as well as tail lights and turn signals.
2019 Mitsubishi Mirage rear and side view
2019 Mitsubishi Mirage Safety Features
The 2019 Mitsubishi Mirage features multiple airbags, an anti-lock braking system, electronic brake force distribution, and brake assist.
2019 Mitsubishi Mirage Fuel Consumption
2019 Mitsubishi Mirage 1.2 L petrol engine consumption- 15.1 km/l on average
2019 Mitsubishi Mirage Acceleration
2019 Mitsubishi Mirage 1.2 L petrol engine accelerates from 0-100km/h in 11.9 secs
The 2019 Mitsubishi Mirage Fuel Tank Capacity: 35 liters
Ground Clearance: The 2019 Mitsubishi Mirage has a ground clearance of 6.3 inches which is below the required standard of 6.5 inches on Kenyan roads.
Mitsubishi Mirage spares, especially body parts are not as easily available in Kenya and they are sometimes expensive. Service parts are fairly affordable and easy to find within Nairobi and other major towns.
The 2019 Mitsubishi Mirage provides a solid and comfortable ride. The steering wheel is power-assisted, so it can efficiently adapt to road curves and bends. Occupants have a commanding view of the oncoming traffic as its bonnet is slanted. The cabin is insulated a little bit but passengers can still hear outside noise, especially from the engine.
The Mirage’s approach and departure angles as well as its low ground clearance that is lower than the required standard of 6.5 inches hinder it from being driven off-road as its body components could be damaged.
The suspension system cushions passengers from unstable motions. The brakes are robust and capable of bringing this car to a complete halt so as to avoid any kind of collision. Brake assist, and electronic brake force distribution help in improving the Mirage stability.
2019 Mitsubishi Mirage cluster meter
2019 Mitsubishi Mirage wheel
2019 Mitsubishi Mirage engine
The 2019 Mitsubishi Mirage is regarded as a reliable car. Due to its low ground clearance, one should not be tempted to drive it on off-road terrains as its body components can be damaged. Transmission issues are the most commonly reported problem in this car. Regular service and maintenance are essential so as to avoid experiencing such kinds of problems.
Refer to the Mitsubishi Mirage buyer guide for a thorough reliability report. We also urge that you always follow the instructions in the owner’s manual.
Mitsubishi Mirage Competitors: Honda Fit, Nissan March, Suzuki Alto, and Daihatsu Mira.
What we like about the 2019 Mitsubishi Mirage
Affordable
Stellar fuel economy
Acceleration is very sluggish
Minimal backseat legroom
The 2019 Mitsubishi Mirage leaves to its name as a reliable and fuel-efficient vehicle that can serve the owner for a very long time if well-serviced and maintained. Folks residing in the metropolis will find it ideal as a daily driver not only because it is not a gas guzzler, but its compactness allows it to easily manouver in confined spaces especially in traffic. People on a tight budget can afford to own this car as its acquisition cost is very reasonable. Click here to download the 2019 Mitsubishi Mirage Owner’s Manual.
We have developed a network of trusted dealers in Japan, South Africa, the UK, and Dubai who supply us with exceptionally high-quality vehicles. Eliminate middlemen and showroom costs by importing the car with us and saving up to KES 500,000. The import process takes 45-60 days from Japan & one week from South Africa and the car is delivered to your doorstep. Click here to choose the best varieties of Mitsubishi Mirage.
2019 Mitsubishi Mirage side view
