2019 Nissan Juke Review
The latest generation Nissan Juke has received numerous facial rejuvenations that are eye-catching and sure to turn heads. Its refined appearance has earned it its status as one of Kenya's most sought-after vehicles. Notwithstanding its countless benefits, it competes with the Honda Vezel, Mitsubishi RVR, Subaru XV, and Nissan Dualis.
2019 Nissan Juke front and side view
The F15 marked the first generation of the Nissan Juke, which began production in 2010 and continued until 2019. The Nissan Juke is currently in its second generation, designated the F16. The vehicle is larger and based on an all-new CMF-B platform shared with the second-generation Renault Captur and the fifth-generation Renault Clio. The new platform makes extensive use of high-strength steel which is claimed to offer better stability, performance, and cornering capabilities.
The 2019 Nissan Juke is available with two engine options, a 1.0-liter HR10DDT (petrol) and a 1.6-liter HR16DE (Hybrid) linked to either a 6-speed manual or 7-speed dual-clutch automatic eCVT.
2019 Nissan Juke Grades
- Nissan Juke ST- This grade comes with a keyless entry, push-button start, Bluetooth connectivity, a USB input socket, a backup camera, and a navigation system.
- Nissan Juke Ti-S (FWD) – This grade has an electronic brake force distribution, climate control, cruise control, an engine start button, and a multi-function display screen.
- Nissan Juke Ti-S (AWD)- This grade features a 12-volt power outlet, power windows, a trip computer, a voice-activating system, and traction control.
- Nissan Juke NISMO RS (FWD) – This grade boasts a rear roof spoiler, body-colored door mirrors, parking distance sensors, AM/FM Radio, and 17-inch alloy wheels.
- Nissan Juke NISMO RS( AWD)- This grade is fitted with climate control, power windows, power mirrors, cruise control, and Bluetooth connectivity.
The cabin of the 2019 Nissan Juke is notably more spacious than previous iterations, thanks to a 105mm larger wheelbase. The first row has plenty of legroom and headroom, and the seats can be reclined to your liking. There is plenty of knee room on the second row. Taller passengers may feel constrained due to the slanted roofline, which results in limited headroom. The window line is still higher than in rivals, and over-the-shoulder visibility is better.
2019 Nissan Juke second row
The 2019 Nissan Juke includes several storage compartments designed to enhance occupant comfort. The first row has two cupholders, a glovebox compartment, door panel storage, and a center console. Door pockets and jacket pockets are included in the second row.
2019 Nissan Juke cupholders
In comparison to the previous generation, the 2019 Nissan Juke offers a larger cargo area. The rear seats can be folded if more space is needed.
2019 Nissan Juke boot space
The 2019 Nissan Juke is larger than previous iterations, exuding both masculinity and sophistication. Nissan has redesigned the new-generation Juke based on suggestions from its enthusiasts. The front end features a V-shaped grille with the Nissan emblem to assert its status.
The headlights, complemented by LED daytime running lights which are more thinner and sleek, add elegance and beauty. The lower fascia is dominated by air vents that not only help cool the engine but also improve the car’s aerodynamics. A high waistline and wide wheel arches define the side profile. The contours running from the A-pillar to the rear are striking. The rear end features a lip spoiler linked to a sloping roofline, giving it a distinctive appearance.
Tail lights and turn signals are also prominent. Higher trim levels include a sunroof to help let in more natural light.
2019 Nissan Juke rear view
2019 Nissan Juke Safety Features
The 2019 Nissan Juke features electronic brake force distribution, cruise control, multiple airbags, and traction control.
2019 Nissan Juke Fuel Consumption
2019 Nissan Juke 1.0 L petrol engine consumption- 19.7 km/l on average
2019 Nissan Juke 1.6 L hybrid engine consumption- 18.4 km/l on average
2019 Nissan Juke Acceleration
2019 Nissan Juke 1.0 L petrol engine accelerates from 0-100km/h in 13.3 secs
2019 Nissan Juke 1.6 L hybrid engine accelerates from 0-100km/h in 10.5 secs
The 2019 Nissan Juke Fuel Tank Capacity: 46 liters
The 2019 Nissan Juke has a ground clearance of 6.7 inches.
The 2019 Nissan Juke boasts a smooth and comfortable ride. The steering wheel responds well to road curvature, which is very handy while overtaking on the highway or maneuvering in tight spaces. It maintains excellent control in tight corners, with little to no body roll. The suspension mechanism shields the passengers from instabilities caused by rough road surfaces.
The cabin is well-insulated to keep outside noise out of the passenger’s ears. The brakes are powerful enough to bring this car to a halt in a matter of seconds, eliminating any disasters. This vehicle includes electronic brake force distribution and traction control to improve stability.
2019 Nissan Juke gear shift
The 2019 Nissan Juke is a reliable vehicle. It can be driven in mild off-road conditions due to its high ground clearance. It does, however, have flaws, just like every other car. Transmission and clutch problems are the most typical complaints from Juke owners. To avoid such issues, regular servicing and maintenance are required.
Refer to the Nissan Juke buyer guide for a thorough reliability report. We also urge that you always follow the instructions in the owner’s manual.
Nissan Juke Competitors: Honda Vezel, Mitsubishi RVR, Subaru XV, and Nissan Dualis.
What we like about the 2019 Nissan Juke
Agile handling
Extensive color customization options
Limited rear passenger headroom
Poor rear visibility
The 2019 Nissan Juke is fantastic for commuting in metropolitan areas owing to its good fuel efficiency and nimble handling. Individuals on a tight budget can afford to buy this car, since its price together with service and maintenance are reasonable. Click here to choose the best variety of Nissan Juke.
2019 Nissan Juke side view
