2019 Toyota Harrier Review
Toyota Harrier is setting the pace in the Kenyan market when it comes to exterior appearance, fuel economy, and reliability. This is evident on the roads as you can barely fail to spot a Harrier. Despite the fact that it is quite pricey, it provides good value for money. It contends against the Mitsubishi Outlander, Nissan Murano, Volkswagen Touareg, Mazda CX5, Lexus NX, Mercedes Benz GLA, and Honda CRV.
2019 Toyota Harrier front and side view
Toyota Harrier production began in 1998 and is still going on today. In overseas countries, the Harrier was rebadged as the Lexus RX from March 1998 until December 2008.  Toyota had not yet begun selling the Lexus brand to Japanese customers at the time. The second generation Toyota Harrier, designated XU30, debuted alongside the export Lexus model in 2003.  It was nearly identical to the Lexus RX during its first and second versions.
The third-generation Harrier, known as the XU60, was launched in 2013 as a separate model line based on a platform independent from the RX. The Toyota Harrier XU80, the fourth generation, was released in 2020 and is continuing in production today.
The 2019 Toyota Harrier is available with three engine options: a 2.0 L 3ZR-FAE (Petrol), and a 2.5 L 2AR-FXE (Hybrid) which are coupled to a 6-speed automatic and eCVT transmission (Hybrid). Click here to purchase the 2019 Toyota Harrier Buyer’s Guide.
2019 Toyota Harrier Grades
  1. Toyota Harrier Grand- This grade comes with an air conditioner, AUX/USB input socket, Bluetooth connectivity, anti-lock braking assist, and blind spot monitor.
  2. Toyota Harrier Elegance- This grade is fitted with power steering, privacy windows, power mirrors, and MP3-compatible audio.
  3. Toyota Harrier Premium- This grade has a rear spoiler, traction control, 12-volt power outlet, reverse camera, and 18-inch alloy wheels.
  4. Toyota Harrier GS- This grade is equipped with a multi-function display, active brake assist, climate control, and reclining seats.
  5. Toyota Harrier Premium Advanced- This grade boasts power windows, power mirrors, Bluetooth connectivity, intermittent wipers, and a start/stop button.
The 2019 Toyota Harrier has a distinctively designed cabin that counts as luxury.
With reclining seats, the first row has ample headroom and legroom to support a desired position. The second row is also impressive, with plenty of knee and headroom.
2019 Toyota Harrier first row
2019 Toyota Harrier second row
The 2019 Toyota Harrier encompasses several storage compartments that greatly contribute to a passenger’s comfortability. The first row incorporates four cupholders, a glove compartment box, and door panel storage. The second row is fitted with two cupholders mounted on the armrest, jacket pockets, and door pockets.
2019 Toyota Harrier cupholders
The cargo area of the 2019 Toyota Harrier is roomy and can accommodate small to medium-sized luggage. The room is increased much further when the back seats are folded.
2019 Toyota Harrier boot space
The 2019 Toyota Harrier has a sophisticated, sporty, and attractive design. The front end has LED headlights as well as daytime running lights. The lower fascia features a wide grille and fog lights for a sleek appearance. Toyota uses an eagle-like emblem which is placed slightly above the grille, giving the automobile a powerful appearance.
LED tail lights and turn signals are visible on the back end. The lip spoiler is neatly placed on the tailgate, which is electronically driven.
2019 Toyota Harrier rear and side view
2019 Toyota Hilux Safety Features
The 2019 Toyota Harrier features an anti-lock braking system, child safety locks, side airbag, driver airbag, passenger airbag, brake assist, vehicle stability control system, parking sensor, crash sensor, traction control, front impact beams, stability control, and various driver-assistance technologies such as lane departure warning, adaptive cruise control, and blind-spot monitoring.
2019 Toyota Harrier Fuel Consumption
2019 Toyota Harrier 2.0 L petrol engine consumption- 15.4 km/l on average
2019 Toyota Harrier 2.5 L hybrid engine consumption- 18.5 km/l on average
2019 Toyota Harrier Acceleration
2019 Toyota Harrier 2.0 L petrol engine accelerates from 0-100km/h in 12.0 secs
2019 Toyota Harrier 2.5 L hybrid engine accelerates from 0-100km/h in 11.2 secs
2019 Toyota Harrier Fuel Tank Capacity: 56 liters
The 2019 Toyota Harrier has a ground clearance of 7.4 inches.
The Harrier shares many parts with other Toyotas such as the RAV4, Crown, Vellfire, and the Prado. The parts are well-priced and available in major towns across the country. Electronic components such as batteries for the Hybrid are expensive and not readily available in the market.
The 2019 Toyota Harrier provides a satisfying on-road and mild off-road experience. The steering wheel responds well to road curvature, making the car easy to drive. The suspension system is sufficient because passengers are thoroughly cushioned from the unsteady motions caused by the uneven road surface.
The interior is extremely well insulated, so noise is blocked from reaching the passengers. Some of the features included in this vehicle are traction control, electronic brake force distribution, and an anti-lock braking system.
2019 Toyota Harrier cluster meter
The 2019 Toyota Harrier is regarded as a dependable vehicle. It gets an average rating because of its durability and good fuel efficiency. Its ground clearance allows it to navigate off-road terrain, although extreme off-road surfaces should be shunned to avoid damaging the body components.
Regular repair and maintenance are recommended to maximize this vehicle’s potential to its fullest. Click here to purchase the 2019 Toyota Harrier Buyer’s Guide.
Toyota Harrier Competitors: Mitsubishi Outlander, Nissan Murano, Volkswagen Touareg, Mazda CX5, Lexus NX, Mercedes Benz GLA, and Honda CRV.
What we like about the 2019 Toyota Harrier
Sleek interior
Some models are costly
The 2019 Toyota Harrier is a sturdy and durable vehicle with an attractive interior and exterior. Individuals with families may find it to be their ideal vehicle. The same applies to metropolitan commuters looking for an exquisite vehicle with good fuel economy. People on a tight budget may not be in a position to own this car due to its high asking price. Click here to download a copy of the 2019 Toyota Harrier Owner’s Manual.
Click here to choose the best variety of Toyota Harrier.
2019 Toyota Harrier side view
