2019 Toyota Passo Review
The Toyota Passo also referred to as the Daihatsu Boon, has made significant inroads into the Kenyan market. It rose to prominence swiftly because of its excellent fuel economy, practicality, and durability. Mazda Demio, Toyota Vitz, Honda Fit, Suzuki Waggon R, Subaru Trezia, Nissan Note, and Mitsubishi Colt are its rivals.
The first model Toyota Passo, designated M300, was produced from 2004 to 2010. The second-generation Toyota Passo M600 went into production in 2010 and continued until 2016.
The third-generation Passo, the M700, debuted in 2016 and is still in production. The Passo now has a new collision avoidance system (Smart Assist III) that can identify pedestrians, vehicles, preceding and oncoming vehicles, and obstructions and then activate various driver aid systems such as informing the driver or switching between low and high beams.
The 2019 Toyota Passo is available with two engines: a 1.0 L 1KR-FE (Petrol) and a 1.3 L 1NR-FE (Petrol) with a Continuously Variable Transmission (CVT).
2019 Toyota Passo Grades
- MODA 4WD CVT- This grade comes with a CD player, air conditioning, and power windows.
- MODA CVT- This grade has a digital center console interface and a CD player.
- MODA G PACKAGE- This grade is fitted with anti-lock brakes, air conditioning, and power steering.
- MODA G PACKAGE 4WD- This grade boasts halogen headlights, diode fog lights, and a light sensor.
- X 4WD CVT- This grade is equipped with vehicle stability control, power steering, and a radio.
- X CVT- This grade comes with an air conditioner, power mirrors, and power windows.
- X G PACKAGE 4WD- This grade has privacy glass, rear glass heat, and a rear spoiler.
- X G PACKAGE- This grade is fitted with a back wiper, audio control on the steering wheel, and an engine start button.
- X L PACKAGE S 4WD- This grade boasts a centralized door lock and keyless entry.
- X L PACKAGE S- This grade is equipped with driver and passenger airbags.
- X S 4WD- This grade comes with traction control, an anti-lock braking system, and electronic brake-force distribution.
- X S- This grade has a lane keep assist and a collision mitigation system.
The 2019 Toyota Passo is a conventional automobile that is simple and practical.
There is plenty of leg and headroom in the first row. Seats can be reclined to allow a more ergonomic position. Small and medium-sized people will have appropriate headroom and knee room on the second row. Taller folks may experience discomfort.
The 2019 Toyota Passo has a glovebox, a center console, and door pockets in the first row. Jacket pockets can be found in the second row.
The 2019 Passo has a spacious boot that can be expanded by folding the back seats flat.
Furthermore, the rear seats may be folded in a 60/40 split to provide for varied seating arrangements.
The 2019 Toyota Passo is a minuscule hatchback with a contemporary look. It comes in a range of colors to suit your persona
A miniature grille and headlamps on both sides adorn the front end.
The design is stable and offers excellent visibility. Furthermore, the alloy rims and fog lights add a splash of vibrancy.
In the back, there are taillights and turn signals. The Toyota logo is also prominent.
2019 Toyota Passo Safety Features
The 2019 Toyota Passo is fitted with anti-lock braking systems (ABS), electronic stability control (ESC), multiple airbags, lane departure warning, vehicle stability control, and forward collision warning,
2019 Toyota Passo Fuel Consumption
2019 Toyota Passo 1.0 L petrol engine consumption- 24.2 km/l on average
2019 Toyota Passo 1.3 L petrol engine consumption- 23.4 km/l on average
2019 Toyota Passo Acceleration
2019 Toyota Passo 1.0 L petrol engine accelerates from 0-100km/h in 14.3 secs
2019 Toyota Passo 1.3 L petrol engine accelerates from 0-100km/h in 12.1 secs
The 2019 Toyota Passo Fuel Tank Capacity: 36 liters
The 2019 Toyota Passo has a ground clearance of 6.1 inches which is below the minimum required standard on Kenyan road.
The benefit of having a Toyota vehicle is that spare parts and body components are generally available because they are shared among Toyota automobiles. The same applies to the Passo
The 2019 Toyota Passo offers a smooth and solid ride. The steering wheel is simple to use and responds to road curvature, which is handy while passing other vehicles or maneuvering in a parking lot. The suspension technology protects passengers from aggressive motions.
Because it is not very heavy, the braking system can bring this car to a halt in a matter of seconds, preventing potential accidents.
Some of the advances featured in this car to increase its stability are an anti-lock braking system, vehicle stability control, and electronic brake force distribution.
The 2019 Toyota Passo has a reputation for dependability. Due to the Passo’s low ground clearance, which is less than the necessary level on Kenyan highways, driving on off-road terrain risks damaging the body components.
Refer to the Toyota Passo buyer guide for a thorough dependability report. We also urge that you always follow the instructions in the owner’s manual.
Toyota Passo Competitors: Mazda Demio, Toyota Vitz, Honda Fit, Suzuki Wagon R, Subaru Trezia, Nissan Note, and Mitsubishi Colt.
What we like about the 2019 Toyota Passo
Reliable
Good visibility
The 2019 Toyota Passo is an excellent vehicle for those with small families. Using it in a business, such as a taxi, allows one to maximize profits because its fuel consumption is quite low. This car’s service and maintenance are inexpensive thus making it to be within the limit of individuals on a tight budget. Click here to download a copy of the 2018 Toyota Passo Owner’s Manual.
