2019 Toyota Porte Review
The Toyota Porte is a mini multi-purpose vehicle that has gained popularity in Kenya due to its excellent fuel efficiency, spacious cabin, and practicability. As much as it appeals to those with small families, business proprietors find it useful as a cab. It competes with the Nissan Cube, Mazda Scrum, Peugeot Partner, and VW Caddy.
2019 Toyota Porte front and side view
The Toyota Porte’s first iteration, known as the AP10, was manufactured from 2004 to 2012. The second version of the Porte codenamed XP140, began production in 2012 and continued up to 2020. The Toyota Spade, a more masculine variation, debuted in 2012 and is available alongside the Porte.
The 2019 Toyota Porte is available with two engines: a 1.3 L 1NR-FE (Petrol) and a 1.5 L 1NZ (Petrol), both of which are coupled to a CVT.
2019 Toyota Porte Grades
- Toyota Porte F- This grade comes with power sliding doors, power mirrors, chrome door handles, privacy glass, power window front, keyless entry, an Isofix bar, a hill-start control system, a lane-keep assist, a collision mitigation system, and an air conditioner.
- Toyota Porte X- This grade is fitted with a Radio/CD player, electric sliding doors, a centralized door lock, traction control, an engine start button, power windows, and chrome door handles
The 2019 Toyota Porte boasts a roomy cabin that is straightforward and utilitarian. The first row has plenty of leg and headroom, and the seats may be adjusted to a comfortable posture. The second row is cozy and roomy with plenty of leg and headroom.
2019 Toyota Porte first row
2019 Toyota Porte second row
The 2019 Toyota Porte has numerous cabin compartments for smartphones, beverages, goggles, handbags, and other stuff. In the first row, there are two cupholders, door panel storage, and a glove box. The second row includes two cupholders as well as additional storage.
2019 Toyota Porte cabin storage
The 2019 Toyota Porte has a sizable boot that can accommodate small and medium-sized bags. The second row of seats can be retracted if more space is needed.
2019 Toyota Porte boot space
The boxy design of the 2019 Toyota Porte allows for a large interior. The front end is distinguished by a sloping bonnet and big dual headlamps. The big Toyota symbol contributes to the brand’s visibility. A modest grille that extends almost to the lower fascia is noticeable, as are fog lights giving the vehicle an appealing design.
The side profile has an electronically actuated slide door, which is very useful while boarding or alighting the vehicle. Tail lights and turn signals can be spotted in the rear end.
2019 Toyota Porte rear and side view
2019 Toyota Porte Safety Features
The 2019 Toyota Porte features multiple airbags, lane-keep assist, brake assist, an anti-lock braking system, electronic brakeforce distribution, a hill-start control system, a collision mitigation system, and traction control.
2019 Toyota Porte Fuel Consumption
2019 Toyota Porte 1.3 L petrol engine consumption- 19.8 km/l on average
2019 Toyota Porte 1.5 L petrol engine consumption- 19.2 km/l on average
2019 Toyota Porte Acceleration
2019 Toyota Porte 1.3 L petrol engine accelerates from 0-100km/h in 13.2 secs
2019 Toyota Porte 1.5 L petrol engine accelerates from 0-100km/h in 12.8 secs
The 2019 Toyota Porte Fuel Tank Capacity: 45 liters
The 2019 Toyota Porte has a ground clearance of 5.9 inches which is below the required standard on Kenyan roads.
The advantage of owning a Toyota is that spare parts and other body components are readily available because they share several components. The Porte is no different.
The 2019 Toyota Porte rides smoothly and comfortably. Because the steering wheel responds to road curvature, it is easier to handle. When approaching tight corners, however, it is best to slow down because Porte has a tendency to lean excessively.
The suspension system provides a smooth ride free of twitchy vibrations produced by uneven road surfaces to the vehicle’s occupants. This car’s braking system is strong enough to bring it to a stop, which helps to avoid potential accidents.
This car also incorporates electronic brake force distribution, an anti-lock braking system, lane-keep assist, and traction control, all of which contribute to its overall stability.
2019 Toyota Porte Wheel
The 2019 Toyota Porte is considered a reliable car. However, because of the low ground clearance, off-road driving shouldn’t be attempted because the body components may be damaged. Transmission problems are the most often reported complaints by Porte owners. Regular servicing and maintenance are required to avoid these kinds of issues.
Refer to the Toyota Porte buyer guide for a thorough dependability report. We also urge that you always follow the instructions in the owner’s manual.
Toyota Porte Competitors: Nissan Cube, Mazda Scrum, Peugeot Partner, and VW Caddy
What we like about the 2019 Toyota Porte
Outstanding fuel efficiency
Affordability
The 2019 Toyota Porte is a versatile and reliable car with excellent fuel economy. Folks with small families may find it pleasant. Because servicing and maintenance are not exorbitant, people on a tight budget may be able to purchase this car. Click here to download a copy of the 2019 Toyota Porte Owner’s Manual.
Click here to choose the best variety of Toyota Porte.
2019 Toyota Porte side view
