2019 Toyota Sienta Review
The Toyota Sienta's popularity on Kenyan roads has skyrocketed because of its excellent fuel efficiency, dependability, and practicality. In Toyota's MPV lineup, it sits below the Voxy/Noah and above the Roomy. It competes with the Honda Freed, Honda Fit Shuttle, Volkswagen Touran, and Peugeot Partner.
2019 Toyota Sienta front and side view
The first generation Toyota Sienta dubbed the XP80, was released in 2003 and remained in production until 2015. In 2006, the Sienta received a makeover with new colors such as apple green and metallic blue.
Toyota Sienta’s second generation, known as the XP170, began production in 2015 and continued until 2022. It ditched the boxy appearance of its predecessor in favor of an upgraded exterior design inspired by the shape of a trekking shoe. Interior space has been improved as well when compared to prior generations.
The Toyota Sienta is built on the NBC platform, which is shared by the Vitz, Platz, Porte, and other models. The 2019 Toyota Sienta comes with two engines, a 1.5-liter 1NZ-FE (petrol) and a 1.5-liter 1NZ-FXE (hybrid), both of which are linked to a CVT and an eCVT (electronic continuously variable gearbox).
2019 Toyota Sienta Grades
  1. FUNBASE G 5 Passengers- This grade comes with privacy glass, electronic brakeforce distribution, power windows, an Isofix bar, and an anti-lock braking system.
  2. FUNBASE X 5 Passengers- This grade has traction control, an air conditioner, a Radio/DVD player, a back wiper, mud-flaps, keyless entry, and fog lights.
  3. G 6 Passengers- This grade is equipped with a collision mitigation system,  an electronic brake force distribution, and an automatic air conditioner.
  4. G 7 Passengers- This grade boasts a hill-assist control system, an air conditioner, 4 speakers, a damping control system, and an alarm system.
  5. G CUERO 6 Passengers- This grade is equipped with a rear window defroster, a sunroof, AM/FM Radio, and a navigation system.
  6. G CUERO 7 Passengers- This grade has a power slide door, power mirrors, privacy glass, a CD player, and an electronic brake force distribution.
  7. X 6 Passengers- This grade is fitted with power steering, an anti-lock braking system, and an air conditioner.
  8. X 7 Passengers- This grade comes with an alarm system, AM/FM Radio, power slide door, a collision mitigation system, and an Isofix bar.
The 2019 Toyota Sienta’s interior is basic but attractive.
The first row has lots of headroom and legroom, and the seats can be reclined to fit a desired posture. The second row provides adequate headroom and knee room. Because of the limited legroom and headroom, the third-row seats are only appropriate for children.
2019 Toyota Sienta first row
2019 Toyota Sienta second row
To improve passenger comfort, the 2019 Toyota Sienta features numerous compartments for storage. A small central console, a glove box, two cup holders, and door pockets are included in the front row. The second row has two cupholders and door pockets. Cup holders are available to third-row passengers.
The cargo space in the 2019 Toyota Sienta is sufficient for small and medium-sized goods. If more space is required, the second and third rows of seats can be folded.
The 2019 Toyota Sienta has a sporty and stylish design.
An enormous grille and Toyota glyph dominate the front of this automobile, while the modern headlights complement the depiction. Fog lights and air vents are located on the bottom fascia. The side profile incorporates sliding doors that open wide to facilitate getting into and out of the back seats easier. Tail lights and turn signals are on the back end.
2019 Toyota Sienta front view
2019 Toyota Sienta rear and side view
2019 Toyota Sienta rear view
2019 Toyota Sienta Safety Features
The 2019 Toyota Sienta features an anti-lock braking system, multiple airbags, electronic brakeforce distribution, a damping control system, a collision mitigation system, and brake assist.
2019 Toyota Sienta Fuel Consumption
2019 Toyota Sienta 1.5 L petrol engine consumption- 19.8 km/l on average
2019 Toyota Sienta 1.5 L hybrid engine consumption- 26.4 km/l on average
2019 Toyota Sienta Acceleration
2019 Toyota Sienta 1.5 L petrol engine accelerates from 0-100km/h in 12.0 secs
2019 Toyota Sienta 1.5 L hybrid engine accelerates from 0-100km/h in 12.3 secs
The 2019 Toyota Sienta Fuel Tank Capacity: 42 liters
The 2019 Toyota Sienta has a ground clearance of 5.9 inches which is below the required standard on Kenyan roads.
One of the advantages of owning a Toyota is that spare parts and other body components are easy to come by because they share many parts. The Sienta is no exception.
The 2019 Toyota Sienta provides a stable and pleasant ride. The steering wheel is accurate, allowing for swift maneuvering in traffic or a parking lot. The suspension system is advantageous in cushioning occupants in the cabin from undesirable movements, especially when traveling on rough road surfaces.
The brakes are reliable and effective, as they can bring this car to a complete stop in a matter of seconds, preventing any accidents.
This vehicle includes technologies such as electronic brake force and an anti-lock braking system.
2019 Toyota Sienta steering wheel and gear shift
2019 Toyota Sienta cluster meter
Because of its excellent fuel efficiency, the 2019 Toyota Sienta has an impressive dependability rating. With respect to its low ground clearance, it is strongly advised not to drive off-road, as you could damage its body components. Owners of Sienta’s most typically experience transmission problems. The car must be serviced and maintained on a regular basis in order to remain in a mint condition.
Refer to the Toyota Sienta buyer guide for a thorough dependability report. We also urge that you always follow the instructions in the owner’s manual.
Toyota Sienta Competitors: Honda Freed, Honda Fit Shuttle, VW Touran, and Peugeot Partner.
What we like about the 2019 Toyota Sienta
Reliable
The 2019 Toyota Sienta is a dependable and versatile vehicle with excellent fuel economy. People with large families will find it appealing due to the availability of a third-row seat. Individuals on a tight budget can afford to buy this car because service and maintenance are inexpensive. Click here to choose the best variety of Toyota Sienta.
2019 Toyota Sienta side view
