2020 NISSAN NV200 REVIEW
The 2020 Nissan NV200 offers compact versatility for both business and personal use. Its boxy, practical design maximizes cargo and cabin space while remaining easy to navigate in urban areas. A unibody structure with MacPherson front struts and a torsion beam rear suspension balances comfort and stability. Inside, the Evalia features flexible seating, dual sliding doors, and smart storage, while the e-NV200 delivers quiet, responsive electric driving. With low running costs, reliability, and practical dimensions, the NV200 is ideal for small businesses, shuttle services, and families seeking a city-friendly van.
The Nissan NV200 has been a central part of Nissan’s compact van lineup since 2009, earning a reputation for versatility, efficiency, and urban practicality. By 2020, the NV200 had matured into a refined solution for both business and passenger use, continuing to balance cargo flexibility with maneuverability in tight city streets.
The NV200 features a clean, functional design with a boxy profile, sliding doors on both sides, and large rear doors, maximizing interior space while remaining compact enough for easy urban navigation. Its styling is practical yet modern, appealing to both commercial operators and families.
Underneath, the 2020 NV200 uses a unibody construction with MacPherson struts at the front and a torsion beam at the rear, delivering a stable and comfortable ride whether fully loaded or lightly occupied. The e-NV200 electric variant adds quiet, responsive performance and zero-emission driving, making it ideal for urban deliveries or passenger transport.
Thanks to its combination of practical design, reliable engineering, and low running costs, the 2020 NV200 remains a dependable choice for small businesses, shuttle services, or families needing a versatile, city-friendly van.
For those considering the Nissan NV200,we have prepared a separate Buyer’s Guide with insights on what to look out for when buying a used model and the common pitfalls to avoid. Click here to purchase the Buyer’s Guide.
2020 Nissan NV200 Grades
Base / Cargo / Standard
Entry-level trims focused on practicality and affordability. Found in markets worldwide, they feature steel wheels, basic fabric interiors, manual air conditioning, and durable black bumpers. Engines include the 1.6L petrol I4 or 1.5L diesel I4 (region-dependent).
Comfort / Evalia / Mid-Level Variants
Mid-level trims designed to balance utility with passenger comfort. Common in urban and fleet markets, these models add sliding rear doors, upgraded cabin materials, infotainment with Bluetooth, and power windows. Most come with the same 1.6L petrol or 1.5L diesel, paired with manual or CVT transmissions.
Premium / Highway / Passenger Plus
Higher-level trims with enhanced convenience and styling. Standard equipment often includes alloy wheels, dual sliding doors, improved infotainment systems, and additional storage solutions. Passenger variants may offer seating for up to 7 and higher-quality upholstery.
e-NV200 Electric Variants
Electric versions available in Standard, Comfort, and Premium trims. Features include quiet electric propulsion, regenerative braking, zero-emission operation, and optional passenger seating configurations. Batteries range from 24 kWh to 40 kWh depending on market and trim.
The interior of the 2020 NV200 focuses on practicality and passenger comfort, balancing a functional design with versatile seating layouts. The dashboard features a clean, no-nonsense design, with higher trims offering an infotainment system with touchscreen, Bluetooth connectivity, and navigation options in select markets. Lower trims emphasize durability with hard-wearing plastics and straightforward controls, while passenger-oriented Evalia and Premium variants feature upgraded materials and improved seat cushioning.
Interior space is competitive for its class. Front seats are supportive for long drives, with good visibility and adjustable seating. Rear passenger space in the Evalia is flexible, with bench seating for up to 5 adults or optional 7-seat layouts in certain markets. Sliding doors on both sides enhance accessibility, and headroom and legroom are sufficient for city commuting or shuttle use.
The 2020 NV200 provides numerous storage solutions to maximize practicality. Front occupants benefit from large door bins, dual cup holders, a center console, and multiple charging outlets, including USB ports in higher trims. The glovebox is well-sized, and additional storage is available in the dashboard and under-seat compartments on passenger variants.
Rear passengers can use seatback pockets, door bins, and fold-down armrests with cup holders on Evalia trims. The flexible seating arrangements allow the rear seats to fold flat, creating extra space for luggage, deliveries, or personal items.
Cargo / Load Space
The cargo variant of the 2020 NV200 is designed for urban and light commercial use. The cargo area measures approximately 1,300 mm in length, 1,550 mm in width, and 1,250 mm in height, offering sufficient space for deliveries, tools, or equipment. Payload capacity varies by engine and market but typically ranges from 600 kg to 700 kg.
Tie-down hooks are provided to secure cargo, and higher trims may feature protective liners to reduce wear and tear. The low floor and wide rear doors make loading and unloading easier, while the sliding side doors improve accessibility in tight spaces. Passenger Evalia models provide additional cargo space behind the rear bench for luggage or supplies, balancing comfort with practicality.
The 2020 Nissan NV200 presents a practical yet modern exterior that emphasizes both utility and city-friendly style. Its boxy profile maximizes interior space, while the short front and rear overhangs make it exceptionally maneuverable in tight urban environments. The front end features a simple, clean grille flanked by large, upright headlights that provide excellent visibility, with daytime running lights included on higher trims for added safety and a contemporary touch.
Distinctive sliding doors on both sides and wide-opening rear doors enhance accessibility for passengers or cargo, making loading and unloading effortless even in narrow streets or crowded parking areas. The sculpted bonnet and subtle body lines give the van a purposeful presence without sacrificing the practicality central to its design philosophy.
Ground clearance is approximately 150–160 mm, offering a balance between easy entry and the ability to handle uneven urban roads. Functional elements such as robust door mirrors, durable bumpers, and optional roof rails or cargo racks enhance versatility for commercial and passenger use.
Higher-spec passenger trims, like the Evalia Premium, introduce subtle styling upgrades, including body-colored bumpers, chrome grille accents, and alloy wheels, giving the van a more polished, passenger-friendly appearance while retaining its functional roots. Optional accessories such as roof racks, protective liners, and cargo partitions allow businesses or families to tailor the NV200 for deliveries, shuttling, or weekend getaways.
The 2020 NV200 is built on a unibody chassis with reinforced structures to deliver safety and stability. Standard safety equipment includes dual front airbags, ABS with EBD, Brake Assist, and Electronic Stability Control (ESC). Higher-spec Evalia trims may include side and curtain airbags, reversing sensors, and a rearview camera to aid parking in tight urban spaces.
Fuel Consumption & Performance
1.6L Petrol Engine: ~12.0–13.5 km/l
1.5L Diesel Engine: ~14.0–15.5 km/l
e-NV200 Electric: 24–40 kWh battery, range ~170–270 km depending on variant
Acceleration (0–100 km/h) for the petrol/diesel variants is roughly 12–14 seconds, while the e-NV200 provides instant torque and smooth, quiet city driving. Fuel tank capacity (petrol/diesel): 50–55 litres, depending on market.
The 2020 Nissan NV200 offers a ground clearance of approximately 150–160 mm (6–6.3 inches), depending on trim and market, providing a balance between easy cabin access and the ability to handle urban obstacles and light-load conditions.
Minor Service: Every 10,000 km — includes engine oil, oil filter, air filter, and basic inspections.
Major Service: Every 20,000 km — includes engine oil, oil filter, air filter, cabin filter, brake fluid, and other scheduled replacements.
Nissan maintains strong parts support globally, and the NV200 benefits from this network. In Kenya and most African markets, routine service parts like filters, brake pads, and belts are affordable and widely available through local dealers and independent suppliers. Body panels, specialized electronics, or e-NV200 battery components can be more expensive and are best sourced from authorized Nissan dealerships or reputable importers.
The 2020 NV200 delivers a composed ride for a compact van, with MacPherson struts at the front and a torsion beam at the rear providing stability under load. Steering is light and precise for urban maneuvering, while the suspension keeps the ride comfortable even when fully loaded. The e-NV200 electric variant adds quiet, instant-torque acceleration, ideal for city deliveries or passenger transport.
The NV200 has a solid reputation for reliability, particularly with the conventional petrol and diesel engines. The unibody chassis is durable, and routine maintenance is straightforward. Many owners report long service life with minimal mechanical issues, making the NV200 a dependable choice for both commercial operators and families. Resale values are generally fair, with higher-spec Evalia or Premium variants attracting stronger demand.
Competitors
The NV200 competes in the compact van segment with models such as:
Toyota Proace City / Verso
Ford Transit Connect
Renault Kangoo
Peugeot Partner / Expert
What We Like About the 2020 NV200
Practical, flexible interior and cargo space
Easy maneuverability in urban environments
Reliable engines with low maintenance costs
Sliding doors and wide rear access for convenience
e-NV200 electric variant offers quiet, zero-emission operation
What We Don’t Like
Base trims feel very utilitarian
Limited premium touches compared to passenger MPVs
Cargo dimensions may feel tight for larger commercial loads
The 2020 Nissan NV200 blends practicality, reliability, and urban versatility, making it an excellent option for small businesses, shuttle services, or families needing a compact but capable van. Its functional design, low running costs, and ease of driving in tight spaces make it a standout in the compact van segment.
If you are looking to import the Nissan NV200 to Kenya, click here to fill out our contact form, and we will get back to you immediately, or email us directly via [email protected].
