2020 Toyota Passo Review
The Toyota Passo also known as the Daihatsu Boon is a compact hatchback whose popularity in urban areas has increased immensely owing to its fuel efficiency, practicality, and its compactness that allows it to maneuver easily in confined spaces or traffic. The Passo has largely been embraced by taxi operators thanks to its excellent return on investment. It competes with the Mazda Demio, Toyota Vitz, Honda Fit, Suzuki Waggon R, Subaru Trezia, Nissan Note, and Mitsubishi Colt.
The first model Toyota Passo, designated M300, was produced from 2004 to 2010. The second-generation Toyota Passo M600 went into production in 2010 and continued until 2016. The third-generation Passo, the M700, debuted in 2016 and is still in production. The Passo now has a new collision avoidance system (Smart Assist III) that can identify pedestrians, vehicles, preceding and oncoming vehicles, and obstructions and then activate various driver aid systems such as informing the driver or switching between low and high beams.
The 2020 Toyota Passo is available in one engine option, a 1.0 L Petrol linked to a Continuously Variable Transmission (CVT).
2020 Toyota Premio Grades
- Toyota Passo X- This grade comes with manual air conditioning, fabric upholstery, 14-inch steel wheels, an anti-lock braking system, power windows, an AM/FM Radio, and a basic infotainment system.
- Toyota Paso XS- This grade has an electronic brakeforce distribution, multiple airbags, parking sensors, automatic climate control, a lane departure warning, power mirrors, a CD player, and a 12-volt power outlet.
- Toyota Passo G- This grade features automatic emergency braking, a CD player, power windows, an AM/FM Radio, an anti-lock braking system, automatic climate control, and a centralized door lock.
- Toyota Passo Moda- This grade boasts a keyless entry, rear parking sensors, an electronic brakeforce distribution, an automatic emergency brake system, a lane departure warning, and power windows.
The 2020 Toyota Passo has a surprisingly spacious cabin that prioritizes functionality. Plastic touches dominate the majority of the cabin as higher grades come stand with leather upholstery. With a seating arrangement for five, both the first and second rows have ample legroom and headroom.
The 2020 Toyota Passo has numerous storage compartments that are used to either keep or hold the gears of its occupants for ease of access and reach. The first row incorporates a glove box, a center console, door panel storage, and two cupholders. The second row includes door pockets, two cupholders, and jacket pockets.
The 2020 Toyota Passo offers 239 liters of boot space when all the seats are in use. The rear seats can be retracted to create more room for more cargo.
The 2020 Toyota Passo has a compact and rounded silhouette that is suitable for driving in urban areas. Up front sits a prominent grille adorned with the Toyota emblem that is used to stamp its presence wherever it traverses. The headlights provide excellent illumination while simultaneously lending it a contemporary appearance.
The side profile is quite conservative featuring body-colored door handles and mirror caps. The 16-inch alloy wheel adds more allure to the vehicle as smooth character lines enhance its dynamism improving aerodynamics.
The rear encompasses taillights and turn signals that match the headlights for a cohesive look. Its tailgate is electronically driven enhancing convenience especially when you want to access the boot but your hands are full of cargo.
2020 Toyota Passo Safety Features
The 2020 Toyota Passo has anti-lock brakes, electronic brakeforce distribution, a lane departure warning, a blind spot monitor, and pre-crash safety.
2020 Toyota Passo Fuel Consumption
2020 Toyota Passo 1.0 L Petrol engine consumption- 25.3 km/l on average
2020 Toyota Passo Acceleration
2020 Toyota Passo 1.0 L Petrol engine accelerates from 0-100km/h in 14.4 secs
The 2020 Toyota Passo Fuel Tank Capacity: 36 liters
Ground Clearance: The 2020 Toyota Passo has a ground clearance of 5.9 inches
Major Service: At 10,000km. Requires an Air Cleaner, Oil Filter, Fuel Filter, ATF Filter, Cabin Filter, Plugs, Front Brake Pads, Rear Brake Pads, ATF Oil, and Engine Oil.
The benefit of having a Toyota vehicle is that spare parts and body components are generally available because they are shared among Toyota automobiles. The same applies to the Passo.
The 2020 Toyota Passo has a smooth and comfortable ride. The steering wheel is power-assisted hence it adapts effectively to road curves. Its compact size enhances its agility thus it can easily maneuver in confined spaces. It has a balanced weight distribution thus minimizing body rolls when cornering.
The engine works in tandem with the transmission system delivering a smooth start and decent acceleration. The brakes are robust and capable of bringing this car to a halt in matter of seconds to avert any kind of mishap. Other features incorporated in this compact car to improve its stability and handling include an anti-lock braking system and electronic brake force distribution.
The 2020 Toyota Passo is considered a reliable vehicle. Owing to its low ground clearance, it is recommended to avoid driving in extreme off-road terrains as you risk damaging its body components. Refer to the Toyota Passo buyer guide for a thorough reliability report. We also urge you to always follow the instructions in the owner’s manual.
Toyota Passo Competitors: Mazda Demio, Toyota Vitz, Honda Fit, Suzuki Waggon R, Subaru Trezia, Nissan Note, and Mitsubishi Colt.
What we like about the 2020 Toyota Passo
- Fuel efficiency
- Reliability
- Compactness
- Affordability
- Limited power
- Low-ground clearance
The 2020 Toyota Passo has a stellar fuel economy that will appeal to eco-conscious individuals. Its compactness allows it to effortlessly maneuver in confined spaces or even traffic. Its efficient engine has low-emission making it environmentally friendly. Individuals on a tight budget can afford to purchase this car owing to its low acquisition cost and manageable service and maintenance. Click here to choose the best varieities of Toyota Passo.
