2020 Toyota Probox Review
The Toyota Probox is a light commercial vehicle that boasts a grassroot following both in urban and rural areas offering a blend of reliability, fuel efficiency, practicality, and versatility. Its workhorse rate & ability to endure and adapt to different terrains make it among the most sought-after cars. The Probox is neither flashy nor tech-savvy, but it ticks all the boxes right. It competes with the Nissan AD Van and Toyota Succeed.
The first generation of the Toyota Probox, known as the XP50/XP160, was introduced in 2002. In 2014, Probox received a redesign that included the addition of a 1NR-FE engine to power it. The 2020 Toyota Probox comes with two engine options, 1.3 L Petrol and a 1.5 L Petrol linked to a CVT or 5-speed manual transmission.
2020 Toyota Probox Grades
- Toyota Probox DX- This grade comes with fabric upholstery, manual air conditioning, power steering, manual windows & door locks, AM/FM Radio, a 12-volt power outlet, and an AUX input.
- Toyota Probox DX Comfort- This grade features a CD player, halogen headlights, an anti-lock braking system, electronic brakeforce distribution, vehicle stability control, AM/FM Radio, power windows, and a centralized door lock.
- Toyota Probox GL- This grade has a touchscreen infotainment system, automatic climate control, halogen headlights, a 12-volt power outlet, a centralized door lock, a CD player, an AUX output, and an electronic brakeforce distribution.
The 2020 Toyota Probox has a plain and utilitarian cabin that focuses on practicality. If you are looking for luxurious features and modern technology, you won’t find them in the Probox. The dashboard is straightforward with a simple and clean layout. The manually operated climate control ensures the passengers enjoy a room temperature that matches their feel and like. The driver has an excellent view and command of the oncoming traffic. The first row offers sufficient legroom and headroom. The second row has ample knee room and headroom.
The 2020 Toyota Probox incorporates numerous storage compartments that are used to either keep or hold the gears of its occupants for ease of access and reach. The first row incorporates a glove box, a center console, door panel storage, and two cupholders. The second row includes door pockets and jacket pockets.
The 2020 Toyota Probox offers 490 liters of boot space when all the seats are in use. The rear seats can be retracted to create more room for more cargo.
The 2020 Toyota Probox features a boxy silhouette that emphasizes its practicality and utility. The front end is quite conservative incorporating a small grille flanked by rectangular headlights. The Toyota emblem is used to assert the presence of the car as the front bumper is integrated with air intakes that play a role in cooling the engine for better performance.
The side profile is also quite minimalistic. The large windows allow natural light to flood into the cabin as the doors open wide to facilitate effortless entry and exit of the passengers. The roofline is high and flat resulting in a spacious interior. Higher grade comes standard with roof rails adding more room for cargo. The steel wheels showcase its readiness to withstand rigorous surfaces and terrains.
The rear has taillights and turn signals. Its large tailgate opens upward to allow for easy loading and off-loading of cargo. The Toyota badging is adorned on the tailgate to further assert the presence of the Probox. The rear bumper is robust and capable of withstanding minor impacts.
2020 Toyota Probox Safety Features
The 2020 Toyota Probox has anti-lock brakes, electronic brakeforce distribution, and pre-crash safety.
2020 Toyota Probox Fuel Consumption
2020 Toyota Probox 1.3 L Petrol engine consumption- 19.5 km/l on average
2020 Toyota Probox 1.5 L Petrol engine consumption- 18.2 km/l on average
2020 Toyota Probox Acceleration
2020 Toyota Probox 1.3 L Petrol engine accelerates from 0-100km/h in 14.2 secs
2020 Toyota Probox 1.5 L Petrol engine accelerates from 0-100km/h in 13.0 secs
The 2020 Toyota Probox Fuel Tank Capacity: 50 liters
Ground Clearance: The 2020 Toyota Probox has a ground clearance of 6.1 inches
Major Service: At 10,000km. Requires an Air Cleaner, Oil Filter, Fuel Filter, ATF Filter, Cabin Filter, Plugs, Front Brake Pads, Rear Brake Pads, ATF Oil, and Engine Oil.
Given the popularity and widespread of the Toyota Probox, its spare parts and body components are readily available.
The 2020 Toyota Probox is renowned for its sturdy and predictable handling. It has a balanced weight distribution that enhances its agility especially when cornering. The power-assisted steering wheel is very precise and responsive and the suspension setup strikes a balance between stability and comfort.
The driver has excellent visibility and command of the oncoming traffic. The brakes are very robust with a high stopping power ready to mitigate any kind of disaster. The engine works in tandem with the transmission system delivering a smooth start and decent acceleration. Other technologies encompassed in this car to improve its stability include adaptive cruise control, stability control, and traction control.
The 2020 Toyota Probox is renowned for its dependability and durability. It has proven to be a reliable vehicle that can sustain relentless usage with proper maintenance, making it a popular choice for commercial reasons. However, like any other vehicle, it is not without flaws. Transmission problems are among the most frequently reported by owners. Regular service and maintenance are required to avoid experiencing such kind of issues
Toyota Probox Competitors: Nissan AD Van, and Toyota Succeed.
What we like about the 2020 Toyota Probox
- Durability & Reliability
- Ease of Maintenance
- Cargo Space
- Fuel efficiency
- Limited advanced safety features
- Basic interior
If you are looking for a commercial vehicle that offers a fusion of practicality, versatility, and reliability, the 2020 Toyota Probox is the go-to car. It boasts a generous cargo space that can haul tons of cargo. It has a stellar fuel economy that makes it viable as a daily driver or for commercial use. Its compact size allows it to maneuver in confined spaces. Individuals on a tight budget are in a position to purchase this car owing to its affordable acquisition cost and low maintenance. Click here to choose the best varieities of Toyota Probox.
