Howo-NX Prime Mover Chassis With Trailer
The Howo-NX Prime Mover Chassis with trailer is a heavy-haul tractor that makes a sensible choice for transporting bulky materials. Its workhorse capability is perfectly complemented by affordable acquisition cost and low maintenance costs. It is considered a reliable and durable truck for heavy-duty applications. It competes with FAW JH6, Auman GTL, Beiben V4 Prime Mover, and Shacman X6000.
Howo-NX Prime Mover With Chassis
Before you read, we would like to let you know that we sale the Howo-NX Prime Mover Chassis with trailer in Kenya. If you are considering to import the Howo-TX 4×2 Tipper, click here to fill out our contact form https://topcar.co.ke/import-your-car/ and we will get back to you immediately or email us directly via [email protected]
The Howo-NX Prime Mover Chassis with trailer is a suitable choice for the following functions;
  • Container transportation
  • General cargo transport
  • Provides a low body to carry (excavators & rollers, factory equipment, graders & bulldozers).
INTERIOR & EXTERIOR
The Howo-NX Prime Mover Chassis with trailer has a practical and functional cabin. The driver has excellent visibility and command of the oncoming traffic. Convenience is enhanced courtesy of power mirrors, a centralized door lock, and power-adjustable seats.
READ ALSO: Howo-TX 6×4 Prime Mover
The Howo-NX Prime Mover with Chassis has a bold and modern look. LED headlights and daytime running lights lend it a contemporary appearance. The iconic Howo emblem is present, stamping its authority wherever it traverses. The power mirrors allow the driver to see all four corners of the truck.
ENGINE & PERFORMANCE
The Howo-NX Prime Mover Chassis with trailer comes with a ZZ4257V344JBIR 9.726 L 4-stroke Diesel engine 6-cylinder inline-4 valves, water-cooling, turbocharging, & intercooling.
This engine produces 380 horsepower at 2200 RPM and 1600 NM of torque at 1300-1500 RPM.
The powertrain is linked to a manual gearbox, 10 forward and 2 reverse AMT gearbox with PTO (Power-take off).
SPECIFICATIONS
Curb Weight: 8,320 kg
Gross Vehicle Weight (with trailer): 50,000 kg
Front Axle Loading Capacity: 7,000 kg
Rear Axle Loading Capacity: 12,000 x 2 kg
Chassis: Frame (TGA single layer)
Fifth wheel: JOST 90# 3.5 inch
Fuel Tank Capacity (600 liters) with a locking fuel cap
READ ALSO: Jetour G700
Clutch: single plate dry diaphragm spring clutch, diameter 430mm, hydraulically operating with air assistance.
Propeller Shaft: double universal joint propeller shaft with gear-shaped coupling flange
Front Axle: Model: VGD71, drum brake, 7T, MAN technology
Rear Axle: Model: MCY13BGS, drum brake, 12T x 2, single reduction with differential locks between wheels and axles, MAN technology, SKF free maintenance wheel hub bearing
Parking Brake: Spring energy, compressed air operating on the rear wheels
Auxiliary Brake: Engine exhaust brake with ABS
Fuel Tank Capacity: 600 liters
READ ALSO: Toyota Urban Cruiser
Voltage: 24 Volts
Batteries: 2×12 Volts, 180 Ah
Alternator: 3-phase, 28V, 1540W
Starter: 24V
For a wider selection of Howo-NX Prime Mover Chassis with trailer models with various colors, mileages, and specifications, visit DEALER.CO.KE
VIDEO REVIEW: 2025 Range Rover Sport
If you are considering to import the Howo-NX Prime Mover Chassis with trailer, click here to fill out our contact form https://topcar.co.ke/import-your-car/ and we will get back to you immediately or email us directly via [email protected]
