Sinotruck Howo H3 Rigid Load 10 & 13 Tonnes
The Sinotruck Howo H3, with a tonnage of 10 & 13, slightly sits above the Howo H2 Rigid, positioning itself as a reliable and economical workhorse outshining the likes of FAW JK6, Mitsubishi Fuso, Isuzu F-Series, Hino 500 Series, and the MAN TGS. This class is very competitive, and the H3 Rigid Load has successfully carved a niche of its own. What could that be? Price. It is the most affordable truck on the market. Before capability and power, Kenyans take a keen interest in price. The H3 Rigid delivers both in equal injection.
Sinotruck Howo H3
Sinotruck Howo H3
Before you read, we would like to let you know that we sale the Sinotruck Howo H3 Rigid in Kenya. If you are considering to import the Sinotruck Howo H3 Rigid, click here to fill out our contact form https://topcar.co.ke/import-your-car/ and we will get back to you immediately or email us directly via [email protected]
Sinotruck Howo H3
Sinotruck Howo H3
The Howo H3 Rigid is a sensible and pragmatic choice for the following functions;
  • Moving freight from one place to another
  • Specialized transport (can be a refrigerator for perishable goods)
  • Regional and urban logistics
  • Light construction and utility support
Sinotruck Howo H3
Sinotruck Howo H3
GRADES
Howo H3 42
Howo H3 52
INTERIOR & EXTERIOR
The Sinotruck Howo H3 has a practical and spacious cabin, slightly bigger compared to the Howo H2. In its class, it boasts the best-looking cabin, from leather upholstered seats to convenient functions like power windows and a central door lock with a remote key.
READ ALSO: 2025 Bentley Flying Spur
Sinotruck Howo H3
Sinotruck Howo H3
Driver comfort is one element that Sinotruck Howo H3 has really capitalized on. The air suspension seat provides a supportive and comfortable ride. You can drive from Mombasa to Malaba without experiencing back pain.
Sinotruck Howo H3
Sinotruck Howo H3
The Sinotruck Howo H3 comes with a sleeper berth, depending on the grade. Long-distance drivers will have a liking for this.
On the outside, the Howo H3 has a blend of modernity and functionality. The standout feature is the LED headlights and daytime running lights that inject a contemporary flare. The front fascia is such a beauty for a truck of its size.
READ ALSO: 2025 Jetour X90 PLUS
Sinotruck Howo H3
Sinotruck Howo H3
ENGINE & PERFORMANCE
The Sinotruck Howo H3 comes with a single engine option. A WPN.6NQ220AO Euro 3 4.58 L inline-four Diesel churning out 220 horsepower at 2,300 RPM and 800 NM of torque at 1200-1800 RPM.
This powertrain is connected to an 8-speed manual transmission with 2 reverse gears.
The Howo H3 has a maximum speed of 100km/h.
Sinotruck Howo H3
Sinotruck Howo H3
SPECIFICATIONS (H3 42 H3 52)
Cab Width: 2080mm (H3 42)  2080mm (H3 52)
Wheelbase: 42000mm (H3 42) 5200mm (H3 52)
Chassis Length: 7600mm (H3 42) 8800mm (H3 52)
Chassis Width: 2420mm (H3 42) 2440mm (H3 52)
Ground Clearance: 195mm (H3 42) 246mm (H3 52)
Sinotruck Howo H3
Sinotruck Howo H3
Gross Vehicle Weight: 18,000kg (H3 42) 18,000kg (H3 52)
Chassis Kerb Weight: 4540kg (H3 42) 4660kg (H3 52)
Front Axle Loading Capacity: 8000kg
Rear Axle Loading Capacity: 10,000kg
Sinotruck Howo H3
Sinotruck Howo H3
Clutch: 350 diaphragm spring clutch, single plate
Steering System Type: Hydraulic system
Suspension: 9-semi elliptical leaf springs, shocks + stabilizer (FRONT)
10 + 9 semi-elliptical leaf springs (REAR)
Parking Brake: Spring energy brake
Auxiliary Brake: Exhaust brake
Fuel Tank Capacity: 200 liters
Sinotruck Howo H3
Sinotruck Howo H3
Voltage: 24 Volts
Batteries: 2×12 Volts, 120 Ah
Alternator: 28V/ 80A
Starter: 4.5 kW
For a wider selection of Sinotruck Howo H3 models with various colors, mileages, and specifications, visit DEALER.CO.KE
READ ALSO: BMW X3
Sinotruck Howo H3
Sinotruck Howo H3
VIDEO REVIEW: 2026 Toyota Hilux
If you are considering to import the Sinotruck Howo H3, click here to fill out our contact form https://topcar.co.ke/import-your-car/ and we will get back to you immediately or email us directly via [email protected]
