2014 Toyota Noah Review
The Toyota Noah is a 7 to 8 seater minivan that can comfortably carry up to 8 full sized adults. It has elevated upright seats that provide natural sitting position and are comfortable for long distance driving. It competes with Nissan Serena, Toyota Voxy, Honda StepWGN, Mitsubishi Delica and Mazda Biante.
The Toyota Noah is a Multi-Purpose-Vehicle(MPV) that was introduced to the Japanese market in late 2001. It was developed from the popular Toyota TownAce/LiteAce platform and is largely the same as the Toyota Voxy.
Most people cannot actually tell the difference and it takes a keen eye to pick the differences. Later in this review, we will highlight the technical differences between the Noah and the Voxy in a way that can help a prospective buyer to make an informed decision.
The Toyota Noah has been in production for 4 generations. The first generation was in production from 2000 to 2004. The second generation was in production between 2004 and 2009. The third generation was in production from 2009 to 2018 and the fourth generation has been in production from 2018 to present.
The 2014 Toyota Noah comes with one engine option which is the 2.0L 3ZR. The 2014 Toyota Noah is only available with an automatic CVT transmission and comes in both 2WD and 4WD options.
2014 Toyota Noah Grades
  1. Toyota Noah X – This is the base model that is a 7 to 8-seater. It comes with manual sliding doors, steel rims, and rear attached seats. It has the following sub-grades (X, XL, XL Selection, XG)
  2. Toyota Noah YY – Same in features as X but a 5-seater
  3. Toyota Noah G – This is the Luxury grade model that comes with features such as dual automatic sliding doors, 7 to 8 seats, captain seats, beige interior, alloy rims, and chrome trim.
  4. Toyota Noah S – This is the sports version of the Noah with features such as Tiptronic, steering shifts, and 7 to 8 seats. It has the following sub-grades (S, SG, Si)
2014 Toyota Noah Interior Legroom & Space
The 2014 Toyota Noah can easily accommodate 8 full-sized adults and their luggage. In the first row, the driver and passenger are afforded good legroom and a good view of the road. Both seats are manually or electrically adjustable and even tall people have sufficient legroom. The second and third rows have good legroom as well, with excellent shoulder space.
Overall, the 2014 Toyota Noah’s interior space is fantastic.
There are several storage compartments in the 2014 Toyota Noah, useful for storing items such as smartphones, beverages, goggles, handbags etc. For the 1st row, there are 4 cup-holders, door panel storage, a storage shelf below the dashboard, a glovebox and a center-box. For the second row, the only storage is on the front seat jacket pockets. For the third row, there are storage spaces on the side pockets and seat jacket pockets.
The 2014 Toyota Noah boot space is decent and can carry medium-sized luggage such as boxes and suitcases. The second and third-row seats can be folded up to create a humongous boot. In this configuration, the Toyota Noah can carry large-sized luggage such as a big fridge, cooker, beds and more.
Other Extras – Double Din Stereo, Navigation(Optional), Reverse Camera, Keyless Entry, picnic seats
The 2014 Toyota Noah’s exterior design closely resembles the Toyota Voxy. The Toyota Noah mostly comes with steel rims but as much as possible we advise that you go for alloy rims. It has got sliding doors on both sides which makes embarking and disembarking an effortless exercise.
2014 Toyota Noah Fuel Consumption
2014 Toyota Noah 2WD Fuel Consumption: 14 km/L (On Average)
2014 Toyota Noah 4WD Fuel Consumption: 12.6 km/L (On Average)
2014 Toyota Noah Acceleration
2014 Toyota Noah accelerates from 0-100 km/h in 9.4 secs.
2014 Toyota Noah Fuel Tank Capacity: 60 Litres
The Toyota Noah has a ground clearance of 6.4 inches (165mm) when unmodified. This is very low for roads in Kenya and the car will definitely not clear some speed bumps. The Toyota Noah can be mistaken for having a good ground clearance due to its tall height, but this is not the case. For a car of its size and considering its loading capacity, the ground clearance is below average by Kenyan standards. There are ways to increase ground clearance, read our guidelines here on how to safely do this.
2014 Toyota Noah Stability and Handling
The 2014 Toyota Noah is solid and stable on the road but it is not designed for sporty or agile handling as it prioritizes comfort and practicality. Therefore when driving around sharp corners it’s advisable to reduce speed and exercise caution. On slippery ground, the 2WD loses traction and spins out of control. The 4WD does a better job as it holds the ground better on slippery roads. Generally, the Toyota Noah is not suited for off-road driving.
Service and Maintenance Costs
Minor Service – Done after every 5,000 km. Requires Air Cleaner, Oil Filter, Engine Oil
Major Service – Done after every 20,000 km. Requires Air Cleaner, Oil Filter, Fuel Filter, Plugs, Front Brake Pads, Rear Brake Pads(If available), ATF Oil, Engine Oil, ATF Filter
The beauty of driving a Toyota in Kenya is that spare parts are relatively cheap and readily available. This is also true for the Toyota Noah. Service parts and suspension parts are readily available. With a monthly budget of about Ksh.6,000/-, you will cover maintenance costs. Body parts such as headlights and side mirrors are somewhat expensive. Used parts generally require negotiations and their prices vary from shop to shop. In Nairobi, most spare shops in the Industrial area and Kirinyaga Road stock these spare parts.
2014 Toyota Noah Reliability
The 2014 Toyota Noah is generally considered a reliable vehicle. Toyota is known for its reputation for building durable and reliable cars, and the Noah is no exception. Regular maintenance and proper care can help ensure the longevity of the vehicle. However, like all vehicles, it may have some common issues such as a malfunctioning air conditioning system, electrical problems, and transmission issues. To minimize the risk of reliability problems, it is recommended to follow the car’s guidelines as per the Owner’s manual and get regular service check-ups.
Resale Value: Good
Toyota Noah Competitors: Nissan Serena, Toyota Voxy, Honda StepWGN, Mitsubishi Delica and Mazda Biante
Purchase Price: Between Ksh.1,500,000 and Ksh.2,000,000
Comprehensive Insurance: Average Ksh. 62,000/ per annum- Or
3rd Party Insurance: Ksh. 7,000/- per annum
Change of Tyres(If necessary) Ksh. 20,000/- for 4 Tyres
See the latest Toyota Noah Prices here
Toyota Noah Vs Toyota Voxy Comparison
Below we have compiled a list of crucial differences between the Toyota Noah and the Voxy. As we earlier pointed out, there is a major confusion between the two. On the outside, it’s hard to tell the difference but there are subtle variations in the grille and taillights. Based on our analysis, the Toyota Noah is superior than the Toyota Voxy. There is no major difference in price between the two in the Kenyan market as they both appear to be equally priced. Below are the differences;
  1. The Toyota Noah has more power ( Noah 158Bhp @ 6200rpm Vs Voxy 140Bhp @5600rpm)
    2. The Toyota Noah has more torque (Noah 196Nm @ 4400rpm Vs Voxy 190Nm @3900rpm)
    3. The Toyota Noah has a better gearbox (Noah 5 speed CVT Vs Voxy 4 speed CVT)
    4. The Toyota Voxy is heavier (Noah 2030Kg Vs Voxy 2070kg)
    5. The Toyota Noah is longer (Noah 4630mm Vs Voxy 4595mm)
    6. The Toyota Voxy is taller (Noah 1850mm Vs Voxy 1875mm)
    7. The Toyota Noah is wider (Noah 1720mm Vs Voxy 1695mm)
    8. The Toyota Noah has better ground clearance (Noah 165 mm Vs Voxy 160mm)
What we like about the 2014 Toyota Noah
  • Spacious interior
  • Comfortable for long distance
  • Multipurpose vehicle
  • Ideal for large families
1. Low ground clearance
2. Poorly placed instrument cluster
The 2014 Toyota Noah is an ideal car for medium size to large families. It can be configured to carry luggage of all sizes thanks to its humongous interior space, foldable seats, and large sliding doors on both sides. If you are looking for an ideal family car the Toyota Noah is what you need.
Where to Buy the 2014 Toyota Noah in Kenya
If you are looking to either import or buy the Toyota Noah locally, we can help you with this process. Over the years, we have developed a network of trusted dealers both in Kenya and Japan who supply us with exceptional cars. Simply call us or send us a message through our contacts below and we’ll get you the right car at the right price.
