2017 Toyota Noah Review
The Toyota Noah is one of the most sought-after Multi-Purpose Vehicles (MPV) in the Kenyan market and a popular choice for families and taxi operators thanks to its ideal space, reliable performance, comfortable ride, and great fuel efficiency. It was introduced in 2001 as a replacement for the Toyota Lite ace. The Toyota Noah shares the same platform as the Toyota Voxy, which was launched around the same time, and shared many of its features and components. It competes with Nissan Serena, Toyota Voxy, Honda StepWGN, Mitsubishi Delica, and Mazda Biante.
The Toyota Noah has been in production for 4 generations. The first generation was in production from 2000 to 2006. The second generation was in production between 2007 and 2014. The third generation was in production from 2014 to 2021 and the fourth generation has been in production from 2022 to present.
The 2017 Toyota Noah is available in two engine options these are the 2.0 L 3ZR-FAE engine and the 1.8 L 2ZR-FXE engine (hybrid). Both are petrol-powered. They are also connected to a continuously variable transmission (CVT), which provides smoother and more efficient shifting compared to the traditional automatic transmission in previous models.
2017 Toyota Noah Grades
2017 Toyota Noah X– This is the base trim that comes with 16-inch aluminum alloy wheels, Automatic HID headlights, fog lights, power-sliding rear doors, power tailgate, rear spoiler, roof rails, Three-zone automatic climate control, heated front seats, power-adjustable driver’s seat, third-row 60/40 split-folding bench seat, 7-inch touchscreen infotainment system, Bluetooth connectivity, steering wheel-mounted audio controls and keyless entry and ignition.
2017 Toyota Noah G– This grade adds extra features such as a touchscreen infotainment system, automatic climate control, and keyless entry.
2017 Toyota Noah S– This trim level adds even more features such as LED headlights, a premium audio system, and a rearview camera.
2017 Toyota Noah Hybrid– This trim level includes a hybrid powertrain, which combines a gasoline engine with an electric motor for increased fuel efficiency.
Interior Legroom & Space
The 2017 Toyota Noah has a spacious interior that can accommodate up to eight passengers. In the first row, the seats are comfortable and provide ample legroom and headroom for passengers. In the second row, the seats are adjustable and provide good legroom, but may be a bit tight for taller passengers. The third-row seats on the other hand are suitable for children or smaller adults and are less comfortable for long-distance journeys.
There are several storage compartments in the 2017 Toyota Noah that can be useful for storing items such as smartphones, beverages, goggles, handbags, etc. In the first row, there are 4 cup holders, door panel storage, a storage shelf below the dashboard, a glovebox, and a center box. For the second row, the only storage is on the front seat jacket pockets. For the third row, there are storage spaces on the side pockets and seat jacket pockets.
The 2017 Toyota Noah has a generous boot space that depends on the number of seats in use. With all seats in place, the Toyota Noah’s boot can carry medium-sized luggage such as boxes and suitcases. However, when the third-row seats are folded down, the space can accommodate bigger cargo such as furniture.
Safety Features – Anti Theft System, SRS Airbags, Toyota Safety Sense, blind spot monitor, rear cross-traffic alert, and a 360-degree camera system.
The 2017 Toyota Noah features a box-like modern and sleek design, which reflects its practicality. It has a bold front fascia, which features a large grille and angular headlights that give it a distinctive appearance. It boasts a long roofline and large windows that provide good visibility for both the driver and passengers. At the rear, it has a wide tailgate that extends upwards giving it a unique look.
2017 Toyota Noah Fuel Consumption
2017 Toyota Noah 1.8 L 2ZR-FXE engine Fuel Consumption: 23Km/L (On average)
2017 Toyota Noah 2.0 L 3ZR-FAE engine Fuel Consumption: 13.1KM/L (On Average)
2017 Toyota Noah Acceleration
2017 Toyota Noah 1.8 L accelerates from 0-100 km/h in 11 secs
2017 Toyota Noah 2.0 L accelerates from 0-100 km/h in 9.6 secs
Toyota Noah Fuel Tank Capacity: 60 Litres
The Toyota Noah has a ground clearance of 6.4 inches (165mm) when unmodified. This is very low for roads in Kenya and the car will definitely not clear some speed bumps. The Toyota Noah can be mistaken for having a good ground clearance due to its tall height, but this is not the case. For a car of its size and considering its loading capacity, the ground clearance is below average by Kenyan standards. There are ways to increase ground clearance, read our guidelines here on how to safely do this.
2017 Toyota Noah Stability and Handling
The 2017 Toyota Noah is stable and handles well as it is built as a family-oriented vehicle with a focus on comfort and safety. Its suspension system is tuned to provide a comfortable ride, while the electric power steering system provides responsive and precise steering.
The Toyota Noah also has a number of advanced safety features and stability control systems, including Vehicle Stability Control (VSC), Traction Control (TRAC), and Hill-start Assist Control. (HAC). These systems work together to help maintain stability and control in a number of driving situations, such as slippery roads.
The 2.0L engine has slightly higher power and torque while the 1.8L engine has better fuel economy.
Service and Maintenance Costs
Minor Service – Done after every 5,000 km. Requires Air Cleaner, Oil Filter, Engine Oil
Major Service – Done after every 20,000 km. Requires Air Cleaner, Oil Filter, Fuel Filter, Plugs, Front Brake Pads, Rear Brake Pads(If available), ATF Oil, Engine Oil, ATF Filter
The beauty of driving a Toyota in Kenya is that spare parts are relatively cheap and readily available. This is also true for the Toyota Noah. Service parts and suspension parts are readily available. With a monthly budget of about Ksh.6,000/-, you will cover maintenance costs. Body parts such as headlights and side mirrors are somewhat expensive. Used parts generally require negotiations and their prices vary from shop to shop. In Nairobi, most spare shops in the Industrial area and Kirinyaga Road stock these spare parts.
2017 Toyota Noah Reliability
Toyota Noah is known for being a well-built and long-lasting vehicle, with many owners reporting no problems even after years of use.
However, some owners have reported transmission issues such as difficulty shifting gears and grinding noises. A few owners have reported suspension system problems.
These problems may not affect all vehicles and their severity may vary.
Regular maintenance and servicing can help prevent some of these issues from occurring.
it is recommended to follow the car’s guidelines as per the Owner’s manual.
Toyota Noah Competitors: Nissan Serena, Toyota Voxy, Honda StepWGN, Mitsubishi Delica, and Mazda Biante
Toyota Noah Vs Toyota Voxy Comparison
Below we have compiled a list of crucial differences between the Toyota Noah and the Voxy. As we earlier pointed out, there is a major confusion between the two. On the outside, it’s hard to tell the difference but there are subtle variations in the grille and taillights. Based on our analysis, the Toyota Noah is superior to the Toyota Voxy. There is no major difference in price between the two in the Kenyan market as they both appear to be equally priced. Below are the differences;
- The Toyota Noah has more power ( Noah 158Bhp @ 6200rpm Vs Voxy 140Bhp @5600rpm)
The Toyota Noah has more torque (Noah 196Nm @ 4400rpm Vs Voxy 190Nm @3900rpm)
3. The Toyota Noah has a better gearbox (Noah 5-speed CVT Vs Voxy 4-speed CVT)
4. The Toyota Voxy is heavier (Noah 2030Kg Vs Voxy 2070kg)
5. The Toyota Noah is longer (Noah 4630mm Vs Voxy 4595mm)
6. The Toyota Voxy is taller (Noah 1850mm Vs Voxy 1875mm)
7. The Toyota Noah is wider (Noah 1720mm Vs Voxy 1695mm)
8. The Toyota Noah has better ground clearance (Noah 165 mm Vs Voxy 160mm)
What we like about the 2017 Toyota Noah
- Comfortable ride
- Multipurpose vehicle
- Low ground clearance
The 2017 Toyota Noah is an ideal vehicle for buyers who want a spacious, fuel-efficient, reliable, and safe vehicle that is easy to drive and can meet a variety of transportation needs. It is a great choice for family road trips, group outings, or even for commercial purposes.
To import the Toyota Noah to Kenya, visit our marketplace https://dealer.co.ke/ or share your contacts through this link https://topcar.co.ke/import-your-car/
