2018 Toyota Voxy review
The Toyota Voxy is one of the most sought after minivans in the Kenyan market due to its spacious interior, comfortable ride, and fuel efficiency. Since its introduction in 2001 the Toyota Voxy has undergone several changes is in currently one of the most reliable Toyota brands. It competes locally with the Toyota Noah, Nissan Serena, Honda StepWGN, Mitsubishi Delica and Mazda Biante.
The Toyota Voxy is a 7 to 8-seater Multi-Purpose Vehicle (MPV) that was introduced to the Japanese market in late 2001 and is currently in the fourth generation.  It was developed from the popular Toyota TownAce/LiteAce platform and is largely the same as the Toyota Noah.
The 2018 Toyota Voxy comes with 2 engine options there are the 2.0-liter 3ZR-FAE engine and the 1.8-liter 2ZR-FAE engine which is used in hybrid models. The 2.0-L engine is connected to an automatic CVT transmission and comes in both 2WD and 4WD options.
2018 Toyota Voxy Grades
  1. 2018 Toyota Voxy S- This is the base grade and comes standard with features like a 2.0L 4-cylinder engine, CVT automatic transmission, air conditioning, power windows, and locks, and a AM/FM/CD stereo with auxiliary input.
  2. 2018 Toyota Voxy X- This trim adds features like a leather-wrapped steering wheel, heated front seats, and a sunroof.
  3. 2018 Toyota Voxy V- The V grade comes with Automatic LED headlights, an auto sliding door, smart key system, a push-button start, fog lights, a rear spoiler, and a leather-wrapped steering wheel.
  4. 2018 Toyota Voxy ZS- This is the highest variant that adds features like a sport-tuned suspension, 17-inch alloy wheels, a body-color grille, and a rear spoiler.
2018 Toyota Voxy Interior, Legroom & Space
The 2018 Toyota Voxy offers a spacious interior that can accommodate up to 8 passengers comfortably.
The dashboard is well-designed, with logically arranged controls that are easy to reach and use. The instrumentation is clear and easy to read, and the center console is well-organized and includes a touch-screen display for the infotainment system.
In the first row, the seats have ample legroom and headroom for the driver and front passenger. In the second row, the seats are also comfortable and can be adjusted to slide forward or backward, allowing passengers to create more legroom. The third-row seats are a bit cramped and are suitable for children or small-sized adults.
The 2018 Voxy has several storage compartments that can be used to store items such as smartphones, beverages, goggles, handbags, etc. In the first row, there are 4 cup holders, door panel storage, a storage shelf below the dashboard, a glovebox, and the center box. For the second row, the only storage is on the front seat jacket pockets. For the third row, there are side pockets and seat jacket pockets.
 2018 Toyota Voxy Boot Space
The 2018 Toyota Voxy offers a generous boot space that medium-sized luggage for a family. However, the second and third-row seats can be folded if additional space is required. In this configuration, the Toyota Voxy can carry large-sized cargo such as a big fridge, cooker, beds, and more.
The 2018 Toyota Voxy boasts a sleek boxy design with a sleek front fascia that incorporates sharp lines and a large, bold grille. The headlights are elongated and slightly angled, giving it a sporty and aggressive look on the road.
The side profile features sharp, creased lines that add to its sporting appearance. Its big windows enable good sight for passengers, and the low beltline makes it appear open and airy. It also has a relatively low stance and a long, flat roofline.
2018 Toyota Voxy Fuel Consumption
2018 Toyota Voxy 2.0 L Fuel Consumption: 14.2 km/L (on average)
2018 Toyota Voxy 1.8 Hybrid Fuel Consumption: 20.6 km/L (on average)
2018 Toyota Voxy Acceleration
2018 Toyota Voxy 2.0 L accelerates from 0-100 km/h in 9.5 secs.
2018 Toyota Voxy 1.8 hybrid accelerates from 0-100 km/h in 11.0 secs.
2018 Toyota Voxy Fuel Tank Capacity: 60 Litres
2018 Toyota Voxy Ground Clearance
The Toyota Voxy has a ground clearance of 6.2 Inches(160mm) when unmodified. This is very low for roads in Kenya and the car will definitely not clear some speed bumps. The Toyota Voxy can be mistaken for having a better ground clearance due to its tall height, but this is not the case. For a car of its size and considering its loading capacity, the ground clearance is dismal. There are ways to increase ground clearance, read our guidelines here on how to safely do this.
2018 Toyota Voxy Stability and Handling
The 2018 Toyota Voxy offers a solid and stable ride with precise handling that’s to its well-tuned suspension system.
It has a low center of gravity and wide stance which helps to keep it stable during cornering and at high speeds.
The 2018 Toyota Voxy’s electric power steering is precise and responsive, allowing confident handling and easy maneuvering in small places. The steering is also designed to provide the driver with good feedback, making it easier to control the vehicle.
It also features Toyota’s Vehicle Stability Control (VSC) technology, which helps to reduce skidding and loss of control in difficult driving situations. The system uses sensors to detect when the vehicle is starting to lose traction and then applies the brakes and/or reduces engine power to help bring the vehicle back into control.
The 2018 Voxy also has Anti-Lock Brakes (ABS) to help prevent the wheels from locking up during severe braking. This enhances braking performance and stability, particularly on wet roads.
2018 Toyota Voxy Service Intervals
Minor Service- At 10,000 km. Requires Air Cleaner, Oil Filter, and Engine Oil
Major Service – At 15,000km. Requires Air Cleaner, Oil Filter, Fuel Filter, ATF Filter, Cabin Filter, Plugs, Front Brake Pads, ATF Oil, and Engine Oil
The beauty of driving a Toyota in Kenya is that spare parts are relatively cheap and readily available. This is also true for the Toyota Voxy. Service parts and suspension parts are readily available. With a monthly budget of about Ksh.6,000/- , you will cover maintenance costs. Body parts such as headlights and side mirrors are somewhat expensive. Used parts generally require negotiations and their prices vary from shop to shop. In Nairobi, most spare shops in the Industrial area and Kirinyaga Road stock these spare parts.
2018 Toyota Voxy Reliability
The 2018 Toyota Voxy is generally regarded as a reliable minivan that can serve you for a long time without major problems. Its reliability is attributed to its sturdy build quality, Toyota’s advanced engineering, and the use of high-quality materials.
However, like any vehicle, it may still experience minor problems. Some of the most reported issues include; unexplained stalling, higher fuel consumption, oil leakage, and engine starting problems.
Regular maintenance and proper care can help mitigate many of these issues. We recommend you follow guidelines as per the Owner’s Manual.
Resale Value: Average
Comparable Cars: Nissan SerenaToyota Noah, Honda StepWGN, Mitsubishi Delica D5 and Mazda Biante
Toyota Voxy Vs Toyota Noah Comparison
Below we have compiled a list of crucial differences between the Toyota Voxy and the Noah. As we earlier pointed out, there is a major confusion between the two. On the outside, it’s hard to tell the difference but there are subtle variations in the grille and taillights. Based on our analysis, the Toyota Noah has more features than the Toyota Voxy. There is no major difference in price between the two in the Kenyan market as they both appear to be equally priced. Below are the differences;
  1. The Toyota Noah has more power ( Noah 158Bhp @ 6200rpm Vs Voxy 140Bhp @5600rpm)
  2. The Toyota Noah has more torque (Noah 196Nm @ 4400rpm Vs Voxy 190Nm @3900rpm)
  3. The Toyota Noah has a better gearbox (Noah 5 speed CVT Vs Voxy 4 speed CVT)
  4. The Toyota Voxy is heavier (Noah 2030Kg Vs Voxy 2070kg)
  5. The Toyota Noah is longer (Noah 4630mm Vs Voxy 4595mm)
  6. The Toyota Voxy is taller (Noah 1850mm Vs Voxy 1875mm)
  7. The Toyota Noah is wider (Noah 1720mm Vs Voxy 1695mm)
  8. The Toyota Noah has better ground clearance (Noah 165 mm Vs Voxy 160mm)
What we like about the 2018 Toyota Voxy
  • Spacious interior
  • Great fuel efficiency
  • Low ground clearance
The Toyota Voxy is a well-rounded and versatile minivan that offers a lot of value for its price. It is a great choice for families and businesses due to its spacious interior can comfortably accommodate up to eight passengers, while its flexible seating configurations make it easy to transport large items.
To Import the Toyota Voxy to Kenya visit our marketplace https://dealer.co.ke/ or share your contacts through this link https://topcar.co.ke/import-your-car/
